September 09, 2026, 16:24:18 pm
352302 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  convert 1300 to 1600 dual head
Author Topic: convert 1300 to 1600 dual head  (Read 5082 times)
mrmut
« on: September 14, 2011, 21:09:54 pm »
Convert 1300 to 1600 dual  head.
Head of 1300 F engine to rewrite the hole cylinder 89.-- to 93,-- whether the head wall will be thin. Huh
This conversion reduces the 7,5:1 to 8,8:1 CR  Grin
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: September 14, 2011, 21:56:47 pm »
 Huh Did not get that one...
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
mrmut
« Reply #2 on: September 14, 2011, 23:22:27 pm »
Which in context ,I do not understand  Embarrassed
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: September 14, 2011, 23:33:48 pm »
This conversion reduces the 7,5:1 to 8,8:1 CR  Grin from 7,5 to 8,8 is an increase/more/higher CR
Do you want to convert a 1300 to a 1600 dual port head?
The '67:
The '59:
Not yet..
mrmut
« Reply #4 on: September 15, 2011, 19:46:11 pm »
Yes. 1300 dual port head to a 1600 cc cylinders
Erlend / bug66
Global Moderator
SCC Event
« Reply #5 on: September 15, 2011, 20:17:15 pm »
Then you need to bore the heads. Could be easier to buy 1600 heads
The '67:
The '59:
Not yet..
mrmut
« Reply #6 on: September 16, 2011, 21:07:52 pm »
I have 1300, 1500, 1600 heads. Wink I want to try 1300 or 1500 in 1600 , аnd 1600 to open the cylinder 90.5.(1776cc)
I have three engines , and I have two 1303s.
1-1303s to be a 1600turbo
2-1303s to be a 1776 with 2x36 drla
 Grin Grin Grin
johnbitch
« Reply #7 on: October 13, 2011, 20:03:04 pm »
Hi there,
I like your plan, machining heads is the best thing to do in your spare time  Wink
Just thought "F" engines always have singleport heads. Dual ports should be from a "AB" engine.
I got only one doubt about it:
Dual port heads for 77mm bore in good shape are getting very, very rare and they are (nearly) the only way to get 12oocc engines converted to dual port engines. In my opinion it would make more sence to build a quick 12oocc from those heads. You can (if you are willing to spend hours & hours) get 100 hp+ out of 77x64.
keep workin`...
just my 2 cent
love speed - hate people
