September 22, 2026, 22:18:41 pm
| | |-+  MSD now in my oval
Author Topic: MSD now in my oval  (Read 5466 times)
vintagewagenwerks
« on: September 15, 2011, 20:32:12 pm »
Today i finished installing my new MSD system to my bug ,lots of work done today and also yesterday ,must be only flashed to the right ignition time because the engine is poping at idle a litle bit.
One fact is that the engine sounds more clear as with the 009 distributor ,can it be or is it illusion?
http://vintage-wagenwerks.blogspot.com/2011/09/installing-my-new-msd-and-linkage_15.html
Itīs better to burn out than to fade away.
vintagewagenwerks
« Reply #1 on: September 15, 2011, 20:56:00 pm »
There are several springs delivered wit the distributor what can i do with them ?Have any one experience with it Huh
« Reply #2 on: September 15, 2011, 21:04:56 pm »
Try one silver light spring and one silver heavy spring as a starter. You can also try the two silver light but I experienced that my engine would not go down to idle quickly enough.
vintagewagenwerks
« Reply #3 on: September 15, 2011, 21:41:58 pm »
ok it is for the character of the ignition?
dangerous
« Reply #4 on: September 15, 2011, 23:03:55 pm »
good work,
but separate those leads,
 and keep the trigger wores from the dizzy away from them!
I think you will like the system.
vintagewagenwerks
« Reply #5 on: September 16, 2011, 18:55:30 pm »
thank you i will keep your advise in mind and change this .today flashed the msd ,only carbs ned some adjustmentwork on the lever arms.
