July 02, 2026, 16:15:21 pm
Latest Member: bigsiembowski
| | |-+  Lil Stink Hound
Author Topic: Lil Stink Hound  (Read 4915 times)
stussyrich
« on: September 18, 2011, 20:58:02 pm »
Lil Stink Hound the story so far. A brief rundown.
no way i'm gonna remember it all, i've slept since then..
This is my 65 uk bug with full history.
It all begins with the car looking like this when i bought it 5 years ago.
The idea was to build a street car with a 2 litre motor, so here you are.
As you can see a whole lot of work went into this build.
The car was driven on the street in the guise for several years until i joined the SAS Renn Wagens and decided to race it.
The full specs are...
2332cc 84x94
044 oval port heads 42x37.5 with 1.4 rockers
web 86c cam
48IDA webers
Engine did 189bhp @6500rpm and 172ft lbs torque@ 4500 rmp on the jaycee dyno.
kcr built pro street box 4.12 ring and pinion, stock 1st 2nd 3rd and an 0.89  4th.
Here is a run down off events and times the car has done upto now, with a few changes on the way.
The first time out was at vw action 2009 where it ran a 13.6, a club qualifying time.
As you can see the car had a change of wheels and tyres for the event to aid with traction and gearing.
Next comes york for the ACE vs ASS shootout and a new pb of 13.2 @ 102mph.
next out was Minis vs beetles at york but no pb and a most embarasing spin on the track.
I'll sort out the video link.
next out did a rwyb day and droppped my ET to 13.0, oh so close to that 12 i'm chasing.
The car was fitted with a set of buggy seats which ment modifying the set mounts and the battery cut of switch.
Also i added a line lock to see if i could get some heat into the tyres.
Next up the facelift and some more mods...
To start with the pedal assembly was modified with the adition of a moon pedal and a custom linkage.
Most of the mods were cosmetic involving another load of pinstriping and gold paint.
Next up was big bang and after a couple of runs managed to completely destroy the clutch on the start line so we changed it at the track so i could drive it home.
And thats the damage. A very broken kushloc disc.
And yes i drove it home, all 3 hours.
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
stussyrich
« Reply #1 on: September 18, 2011, 21:00:28 pm »
Time for a new set of front wheels.
Zero offset centerline bubbles.
Biggest problem i had was having to clearence the calipers and add wheel spacers.
thought i'd add some more gold.
Next outing was the drag day and a mission of running a 12 on radials before the slicks would go on.
Second run 12.99. on with the slicks and ra 12.8
The 356 rims were borrowed of a mate and painted gold and the second hand slicks were added.
vw action 2010.
Managed to run a 12.64 in the night racing any got myself a trophy.
learned how to use the line lock aswell...
Next up drag aday 2011. no pb but a 12.8 on treads.
this made it into volksworld.
Before big bang 2011 alot of the changes included removing everthing that wasn't necessary including the lights, doorcards, rear end, decklid etc.
Jazz fuel cell was added.
The windows were replaced with lexan and the race weight erco's were put on, Some rollcage mods were done including doorbars and a dash bar.
oooops.
Rollcage mods
had to move the guages down.
Lexan windows and cal look rubbers.
Jazz fuel cell
Rear end was removed and wing stays added, also the filter had to be re mounted as there is no inner wings
big bang 2011 saw the car evolve into a race car with alot of changes.
It ran a 12.51 PB so i moved upto 4th in the Renn Wagen et board.
stussyrich
« Reply #2 on: September 18, 2011, 21:01:28 pm »
Next up on the list is the best show i've ever been to... EBI 4.
Ran a new pb of 12.38 @106mph.
You tbe link to a video.
http://youtu.be/3dASO513ks8
The car named and lightened further with a bit of 108 octane race fuel thrown in for good measure.
Oh and has a box chance for a KCR build pro drag with 3.88 ring and pinion. 3.78 1st 2.21 2nd 142 3rd and 1.12 4th with a jaycee alloy spool.
The cooling has come of it.
had to cut the rear valance out to re fit it as i needed too run the deckid.
The name was designed by myself and a mate printed it onto vinyl, i took the doors of the car and added the logo and knifed around the letters and cartoon. luckily had a spare done so put that on the decklid.
Vw action 2011 say the car run a 12.46 in the night racing.. 12th place is ok.
Took the Mrs out for her first run in the car. 12.8 isn't to shabby 2's up.
Jesus
« Reply #3 on: September 19, 2011, 21:15:12 pm »
Looking Great Dude, I hadn't seen the name or signwritting yet!
stussyrich
« Reply #4 on: September 21, 2011, 17:47:14 pm »
Just a small update this week but every little helps.
Oil filler neck replaced.
