October 12, 2026, 21:36:31 pm
| | |-+  2nd gear problem
Author Topic: 2nd gear problem  (Read 5351 times)
jaqo
Bugster Team
« on: October 04, 2011, 19:59:35 pm »
Hello
Here is the photo of my FTC 2nd gear
As you can see it's damaged (thanks to bent hokey stick).
1) stupid question but - are there any chances that it'll work?
2)Since mainshaft looks perfect - is it possible to buy this gear separately or do I have to buy whole set (mainshaft, 1nd and 2nd gears)?
LGK
« Reply #1 on: October 04, 2011, 20:10:38 pm »
Hi Jago,
It seems you have a problem with the " PRO-RING". You can machine the pro-ring off the gear and change it by welding on a new one.
I suppose you're in the UK? Try to call Pete@ COGBOX,he's the man who can help you out there.
No need to buy a new mainshaft as the PRO-RING is located on the gear,not the mainshaft  Wink and as long as the gear has no damage you only need a pro-ring.
Best regards Steve
jaqo
Bugster Team
« Reply #2 on: October 04, 2011, 21:37:29 pm »
I know that, did not know you can change it. I'll take it out and look at it, thanks for the info.
Regards
Jan
