September 23, 2026, 09:20:13 am
| | |-+  EMPI Oil Thermostat - How to plumb up?
Author Topic: EMPI Oil Thermostat - How to plumb up?  (Read 9003 times)
Deanodynosaurs
« on: October 07, 2011, 03:31:28 am »
Got this EMPI oil thermostat of EBAY the other day but a bit unsure how to plumb it in?!
The ports are marked up with E1, E2, C1, and C2. Through E1 and E2 you can see a spring, and through C1 and C2 you can see a brass thingie, a round plate and the bottom of the spring. The thermostat switch is connected to port C2. The thermostat doesn’t seem to fully seal, as if I blow through ports air comes out of all, is this a problem?
If not, obviously something happens to the brass bit as the oil warms up, but what ports go to where?
I.e. which port goes to:
The external fan in
The external fan out
Engine out (via a filter)
Engine in (via a thermostat switch for the fan)
Any advice will be much appreciated.  Smiley  I’ve attached some photos below.
Cheers,
Dude  Cool
« Reply #1 on: October 07, 2011, 05:53:05 am »
Stick it in a pot of water and heat it up.  See what happens.
Deanodynosaurs
« Reply #2 on: October 07, 2011, 11:14:33 am »
Cheers Bruce,
It might come to that...............  Roll Eyes
Was hoping somebody might have fitting instructions/ experience of though. Smiley
Dude  Cool
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: October 07, 2011, 11:46:34 am »
Deciphering:
E- Engine?
C - Cooler?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
pole_80
« Reply #4 on: October 07, 2011, 14:08:46 pm »
Replying to your question regarding the fact the passage is not completely sealed, I think it is normal and correct, because you should guarantee a minimum oil flow to (and back from) the radiator. This will help you when you fill the system with the oil the first time, and will avoid sort of "pressure waves" when the thermostat opens or closes the passage.
Marco.
1302 '72
1303 vert '76
DWL_Puavo
« Reply #5 on: October 07, 2011, 22:46:13 pm »
Previous deciphering was correct:
E1: from engine to thermostat
C1: to cooler
C2: back from cooler
E2: back to engine
Deanodynosaurs
« Reply #6 on: October 20, 2011, 14:16:27 pm »
Ah thank you all. Smiley
I've only just noticed these respnses. Smiley
However, although i'm sure the connections as suggested are right, mechanically it doesnt seen right for whats in the thermostat?  Huh
Cold and not connected C1 is completly open to E1 (see middle picture), i.e. oil will flow through. Seem to be the same for C2 and E2, with a slight opening to let the pressure out  across (last picture). I dont see how this excludes the cooler when the oil is cold?
Confused as ever?  Huh
Dude  Cool
JamieL
« Reply #7 on: October 26, 2011, 14:31:18 pm »
Hi Dude,
I think it you'll find it works on oil pressure, such that;
When oil is cold, pressure is high and will close the port to cooler
When oil is hot, pressure is low and will open the port to cooler
Uninstalled, i.e. in your hand; there is no oil pressure to open/close the ports, hence it appears to be directing oil to the cooler - if that makes sense...?
