October 14, 2026, 21:53:14 pm
Electronic 123 ignition Distributor
Topic: Electronic 123 ignition Distributor (Read 4648 times)
stait9
October 09, 2011, 21:12:43 pm »
Hi
Quick question, has anyone fitted one of these distributors before and what did they think?
Stuart
pep
Re: Electronic 123 ignition Distributor
October 10, 2011, 11:19:16 am »
I have 123 tune version with my 2165cc engine and I like it...few dyno test and works fine in my car
possible to program (with usb cable) 2 different advance curves with rpm limiter
-Petri-
October 10, 2011, 12:10:41 pm »
Have tried a couple. - Both had same problem. Timing was all over the place, causing erratic idle and detonation in the midrange where the cam came in. Tried at least 20 different settings. Lost 4 hp @ 6000 rpm. on one of the engines Went back to a hand adjusted 009 and gained the power immediately and got the nice idle back.
A friend of mine didīnt believe me and ordered anyways. Tried to make it right for 2 weeks. Finally threw the towel and sent it back.
My opinion, - It STINKS! Period. And not worth the money at all.
stait9
October 10, 2011, 21:48:58 pm »
Thanks Guys.
Am currently have some strange issues with 009 with Petronix electronic points, it seems to stumble at lower revs - although it's better when coming back down from high revs. Was trying to figure out solution and remembered reading about these. It's only a 1776 in my daily driver - it's not smooth at all.
October 10, 2011, 22:10:49 pm »
Itīs most likely a jetting problem. Not ignition.
stait9
October 10, 2011, 22:12:02 pm »
Thanks Torben
