September 22, 2026, 18:38:15 pm
| | |-+  flat spotting case for Berg case conversion kit - DIY
Author Topic: flat spotting case for Berg case conversion kit - DIY  (Read 5945 times)
pupjoint
« on: October 21, 2011, 10:51:40 am »
i am not much of a machininist myself, but i got tired of sending my case to the local machine shops here and get crap work, and have to send many times to get the end result.
is there a tool or some drill bit i can buy so i can try to do this myself with my drill press?
pics borrowed from some of threads here.
« Reply #1 on: October 21, 2011, 11:31:06 am »
Not worth doing, IMHO.
pupjoint
« Reply #2 on: October 21, 2011, 11:56:15 am »
any particular reason Keith? that includes the torque change also?
ibg
« Reply #3 on: October 21, 2011, 12:33:04 pm »
the tool is called a counter bore
http://www.mcmaster.com/#metric-counterbores/=el3jc1
If you are increasing the torque on the main studs and perimeter bolts/studs i would check your bore with a dial bore gauge as the crank bore starts to close up with torque increase around the 28/30 lb, though there is a sweet spot, more torque and no distortion.
Or torque to your selected spec and get the case line bored with all the studs and bolts torqued.
« Reply #4 on: October 21, 2011, 15:35:09 pm »
Never did it, never any problems. Torque change? On the 8mm studs round the edge of the case? No way. Just my 2c.
pupjoint
« Reply #5 on: October 21, 2011, 16:19:26 pm »
cool, it is a new case
« Reply #6 on: October 21, 2011, 16:22:41 pm »
(Those are my pics) Do it. But with a drillpress ...Check Felix's posting as well.  "My 67 notch expands to 2.2 liter+beefed up gearbox "
« Last Edit: October 21, 2011, 16:27:08 pm by Harry/FDK » Logged
pupjoint
« Reply #7 on: October 21, 2011, 18:43:39 pm »
cool. yes i have exchanged messages with Felix before.
you used Berg's recommendation on the torque specs?
