July 02, 2026, 17:00:08 pm
Latest Member: bigsiembowski
| | |-+  changing springs
Author Topic: changing springs  (Read 5551 times)
« on: October 23, 2011, 18:11:19 pm »
hey guys,
for breakin, in installed the outer springs only,
now the engine is in the car and i want to add the inner springs.
i bought the schley bro's tool, but there is no fitting for the sparkplug in the kit.
So i cant keep the valves closed.
I remember that the valve locks set themselves in the retainer,
so i am worried i will push the valve in?
« Reply #1 on: October 23, 2011, 18:21:13 pm »
I mangled an old spark plug and bought a fitting for an impact wrench and had a friend solder them together. Works like a charm.
« Reply #2 on: October 23, 2011, 18:42:46 pm »
Or you can call Berg, maybe they will sell you the plug you need by itself to put air in the chamber. just a thought.
Ted
kingsburgphil
« Reply #3 on: October 24, 2011, 03:37:03 am »
Or buy one of these...money well spent.  Just unscrew the Schrader valve to pressurize a cyl.
http://buy1.snapon.com/catalog/item.asp?P65=&tool=diagnostics&item_ID=56142&group_ID=1423&store=&dir=catalog
« Last Edit: October 24, 2011, 03:43:32 am by kingsburgphil » Logged
ibg
« Reply #4 on: October 24, 2011, 13:09:22 pm »
or getto, feed in a length of cotton rope through the spark plug hole, (don't loose the end) turn the pulley until the piston pushes the ball of rope agains the valves. voila  Wink  compress the spring.
« Reply #5 on: October 24, 2011, 13:41:46 pm »
I like the ghetto style Smiley
what thickness of rope is mostly used?
Shag55
Shag Leone, SL-1racing
« Reply #6 on: October 24, 2011, 20:06:08 pm »
Cotten rope, good idea! What ever size fits in your hole. Hope all clearances were checked with the iners installed prior to build. I even # them as there is some variation in compressed heights.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
ibg
« Reply #7 on: October 24, 2011, 22:05:18 pm »
i use 10mm (3/8), but any size would work, you need a friend to hold the pulley or when you compress the spring the engine tries to rotate.
