October 13, 2026, 21:30:04 pm
| | |-+  180mm clutch disc
Author Topic: 180mm clutch disc  (Read 10536 times)
Svang1
« on: November 01, 2011, 22:06:24 pm »
Any suggestions of a 180mm clutch-disc for a 1599 mouse engine with stage1 kennedy pressure plate?
Today it's got a 4-pucked disc, not so good for the gearbox or flywheel over time..
The engine is dynoed to about 154hp and 170Nm, and the gearbox is a newly built kcr (all weddle, no syncro-rings).
The flywheel is cnc machined, so there isn't much left of it.. So I guess much heat would not be the best for the flywheel..
I am going to mainly use the car for some street and circuit-racing..
Already bought a custom 180mm black magic disc from Ron L, but I've heard that the disc produces a lot of heat, not far from the 4 pucked disc..
Haven't found any 180mm discs like Daikin super-disc, wouldn't something like that disc work ok.. ?
Is it ok to machine a 200 daikin disc to 180mm, like Ron did with the black magic disc??
« Reply #1 on: November 02, 2011, 12:14:16 pm »
I would contact CB Performance and ask them to make/order a 180 mm. 4 puck Ezy-lock. Better than the Black magic because it hooks up about as fast but is much lighter, so it doesnt stress the syncroŽs so bad.
Svang1
« Reply #2 on: November 02, 2011, 17:32:35 pm »
Cant find Ezy-lock, just kwik-lock and pad-lock at CB's website.
Is the Eazy lock just special order only?
The gearbox is bulit with Weddle "racing-gears", so the syncros isn't an issue..
« Reply #3 on: November 02, 2011, 19:05:20 pm »
It is special order.
Svang1
« Reply #4 on: November 02, 2011, 19:55:57 pm »
Ok then, I'll order one..
Thanks Torben..
Type1/DVK
« Reply #5 on: November 02, 2011, 22:05:27 pm »
haha, that's quick! so convinced after those words..  Grin
Peter Shattock
« Reply #6 on: November 02, 2011, 23:02:39 pm »
I had more experience than I would have liked in 2010 with 180mm clutch disc's. In terms of the regular organic disc's I found the Semi auto box 180 disc's to be the most durable.
I also decided to make a 180mm black magic disc disc as an option but did not use it as it was not compatible with my aluminum pressure plate. I ended up with a 12 pad disk (6 pads each side) with Kevlar pads on the pressure plate side and ceramic pads on the flywheel side, which I suspect is similar to that which Torben is describing.
To be honest unless your car is very heavy I would be tempted to try the auto stick 180mm disc, as mine was close to being OK with 231nm of torque. The car weighs about 1500lbs.
I would say less is more in this respect, although I did get it wrong and had more frequent service intervals than was ideal in a street car, but I suspect it may work for you.
Its worth shimming the pressure plate too, to check where the sweet spot is in terms of the pressure available.
Good luck!
« Reply #7 on: November 02, 2011, 23:58:02 pm »
Peter, very interesting info.
I didŽnt realize that the semi auto disc had more grip than the stick shift ones.
The reason I recommened the Ezy lock is that it is somewhat "softer" compared to a regular 4 puck race unit, and also holds about 10% less torque. But with the power he has, it should hold up more than enough.
Svang1
« Reply #8 on: November 03, 2011, 21:06:22 pm »
Hi Peter!
Well, CB haven't answered my request yet..
So where can I check out and maybe buying the Semi auto box, 12 pad disc or the auto stick?
In terms of how heavy the car is, it is stock weight..
Peter Shattock
« Reply #9 on: November 11, 2011, 23:04:04 pm »
I got the auto stick one from a friend who just happened to have one, and the Kevlar / ceramic disc was from Kennedy. They were very helpful and sent it to me in kit form as I needed to make it up a little thicker than normal to allow me to shim the pressure plate.
Good luck I hope you find a solution that works.
dangerous
« Reply #10 on: November 12, 2011, 10:14:29 am »
Bergs sell a 3-puck version, and Scat a 4-puck in 180mm.
I had my local clutch guy make my 3-puck disc and am very happy with it:
Car is around 1800lbs and runs high tens@122
Synchros:
<a href="http://www.youtube.com/v/q4eA_RdbNWM" target="_blank">http://www.youtube.com/v/q4eA_RdbNWM</a>
<a href="http://www.youtube.com/v/HgpusDRYNhY" target="_blank">http://www.youtube.com/v/HgpusDRYNhY</a>
Svang1
« Reply #11 on: November 15, 2011, 22:10:52 pm »
Thanks for all replies!
I have now ordered two discs from CB..
And will order a Kep ceramic disc..
Dangerous: I already have a 4 pucked sinter disc..
I'm afraid of ruining the flywheel and gearbox, with hotspots and hard strain to the gearbox (the car is also for street use)..
But the 4 pucked disc gets the car going, no question about that.. Smiley
-Alex-
« Reply #12 on: November 16, 2011, 20:17:35 pm »
How about custom copperhead disc?  200mm is normal order, 228mm is custom, maybe they can make 180mm too?
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=CFC0001&cartid=1115201141811602
