September 23, 2026, 05:50:34 am
| |-+  For sale!
| | |-+  Big turbo prepped heads.
Author Topic: Big turbo prepped heads.  (Read 6185 times)
flatfire
« on: November 09, 2011, 10:29:37 am »
For sale a pair of AJ Sims prepped heads. Never ran My contact details 07923 365 567 (UK) email peterchristie65@gogglemail.com.
Super flow Pro Heads
Berg thick 48mm intake seats with 40mm exhaust seats, Chamber volume 69.8cc, Titanium Inlet valve (48mm) stainless 40mm
Ti Manley retainers, Manley .05"drop keepers,
re-cut pushrod tube surface angle to seal, Cut and set up for K800 springs, Bore 94mm ,Turbo use for over 700hp. Can run up to .720" lift at the valve. All Work and Hand Porting is by A.J.Sims.
Theses heads will awaken any turbo motor and get you into the 9's
£2000
I also have a LBC5.0ProOnly cam to go with the heads including AJs lifters £180
The winners choice when it comes to real HP numbers. Main RPM power range 4,000 to 8,000. Over .580" lift with 1.5.
Along with the heads and cam I have a pair of Racin Jason manifolds for the heads £200
« Last Edit: February 01, 2012, 16:07:12 pm by flatfire » Logged
flatfire
« Reply #1 on: November 11, 2011, 12:44:46 pm »
Will take reasonable offer Smiley
Andy Sykes
« Reply #2 on: November 11, 2011, 13:59:09 pm »
are the manifolds EFI?
cheers andy
flatfire
« Reply #3 on: November 11, 2011, 19:01:25 pm »
The same as below they are for a draw through system. CB have just released a new injector manifold for Comp Eliminators
flatfire
« Reply #4 on: February 01, 2012, 16:08:28 pm »
To the top  Smiley
flatfire
« Reply #5 on: March 06, 2012, 08:35:21 am »
Will take £1500 Smiley
OliveRS
« Reply #6 on: March 22, 2012, 17:38:42 pm »
Looks like CB C/E to me, Superflo 's have a specific valve covers with 4 bolts .
flatfire
« Reply #7 on: March 22, 2012, 23:40:19 pm »
Thanks for the info OliveRS I'm not an expert on the difference. I was told by AJ they would be either CB or Bugpack.
I assumed when there was no markings on the head it was Bugpack.
The heads are sold
