September 22, 2026, 23:56:52 pm
| | |-+  TPS Sensor on 51,5 IDA
Author Topic: TPS Sensor on 51,5 IDA  (Read 6304 times)
Basti
« on: November 13, 2011, 18:45:20 pm »
Hi Guys,
does anybody know a supplier for Throttle positions sensors which
fit on 51,5 IDAs?
Thanks fpr your help!
Basti
- black 62 cal look beetle
- Pro Mod Race car
K-Roc
« Reply #1 on: November 18, 2011, 04:05:01 am »
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=LGU0031&cartid=1117201118316897
Hi this kit is designed for IDF but I'm sure it would be easy to modify for your IDA
« Reply #2 on: November 18, 2011, 15:34:11 pm »
Check this out ... maybe you could get better/more info from TWM.
http://www.twminduction.com/EFI/EFI-FR.html
Good luck, I'm sure something many people could benefit from.
TxT
Basti
« Reply #3 on: January 15, 2012, 15:10:41 pm »
Here is my solution:
I use the kit from aircooled.net for IDF and did some modifications on the bracket....
- Pro Mod Race car
Tom G.
« Reply #4 on: April 02, 2012, 21:41:00 pm »
Hi Basti,
which ignition system do you use? Any electronic-map ignition system?
Regards Tom
Basti
« Reply #5 on: April 03, 2012, 09:02:36 am »
Hi Tom,
I use the electronic ignition of MSS.
Cheers,
Basti
- Pro Mod Race car
