September 22, 2026, 13:11:17 pm
| | |-+  My 65 race car
Pages: 1 ... 5 6 [7] 8 9 ... 32 Print
Author Topic: My 65 race car  (Read 702348 times)
Andy Sykes
« Reply #180 on: May 11, 2012, 16:00:27 pm »
got a bit done today used some of my old conduit bending skills to start making the shift rods
i had to cut the tunnel to get to the shift rods but i will renforce that once done.
seat in
moved the stage brake on to the tunnel
front mount tacked in
its all looking a bit shiney in here lol
cheers andy
Andy Sykes
« Reply #181 on: May 17, 2012, 16:38:10 pm »
small bit done had a change of plan on the aluminuim tude when i connected it all up i thought there was too much flex init so ive used 5/8 cromo tube ( as matt said too in the first place lol) fingers crossed that will be better Smiley
i had to make some bosses
them made the rear gearbox mounts
im still not sure if i will also secure the top of the box cant decide if i may need to or not ?
cheers andy
« Reply #182 on: May 18, 2012, 07:07:40 am »
Amazing job, but I do believe you would get better results with straight shift rods. And without the guides you have on them, I think you will get bending there as the shifter moves in slight arcs.
Anyway keep the pictures coming!  Smiley
Andy Sykes
« Reply #183 on: May 19, 2012, 07:48:23 am »
I agree but the way the shifter and box are I can't     Sad
Bit more done I've removed the rose joints and made some acetal bearings
My next issue is I wanted to get rid of as many bends as possible as the shifter and rods are on opposite sides of the car so I've started making a tri-axle bearing ( if that's the right word) that will have a sort lever on each end. That will mount in side the tunnel to keep the rods straight
Long way to go with this part yet let's just hope it works  :lol:
Cheers andy
m.m.p
« Reply #184 on: May 20, 2012, 07:56:07 am »
hi Andy, i can see you've done loads of work trying to get the shift rods in place and functional, but due to placement of the shifter and box there is no straight run to connect the two, have you thought of using universal shift cables?
good luck
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Andy Sykes
« Reply #185 on: May 20, 2012, 08:37:21 am »
That thought entered my head but for some silly reason in thought you could only pull on those not push, thanks for the heads up they will be much easier to use. I will give a bell tmw to talk engines
Cheers andy
« Last Edit: May 20, 2012, 09:16:26 am by fast65 » Logged
Andy Sykes
« Reply #186 on: May 20, 2012, 11:09:00 am »
Got me thinking I'm sure I've got some of those so up to the loft to look at my small collection of VAG cables lol
And I've found a few woo happy days
Looks like this is going to be much easier Smiley
Cheers andy
Andy Sykes
« Reply #187 on: May 21, 2012, 17:43:34 pm »
Mk1 of the vertigate cable shift rod support to prove the idea, now it works i can make a proper one Smiley
cheers andy
AntLockyer
« Reply #188 on: May 21, 2012, 23:29:23 pm »
Awesome!
12.618 @ 104.87mph
Andy Sykes
« Reply #189 on: May 24, 2012, 18:36:11 pm »
Awesome!
Cheers dude
Little bit more done the cable shift rods have taken a lot of thinking about mainly getting the support inside the tunnel but I think I have cracked that just got to make the production model now I have done the prototype, had to tidy out the workshop and replace a few bushes and cv boot my 4mo that hasn't moved for a year bit that nearly done only got the steering position sensor to change and in for the MOT so I can use her again
Workshop tidy
Started on the top gearbox mount I have an idea for this but I'm going to leave it fluid and see what happens Smiley
Cheers andy
Fasterbrit
« Reply #190 on: May 24, 2012, 19:34:52 pm »
Good work! I love the cable shift approach  Cool
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #191 on: May 28, 2012, 17:39:53 pm »
cheers matt thanks Smiley at last my head scratching has paid off 1st 2nd 3rd and 4th in and working just got to sort reverse tmw
and the seat still fits lol
just got to make good the hole i cut on the chassis now
cheers andy
Andy Sykes
« Reply #192 on: May 29, 2012, 17:54:53 pm »
bit more done today got reverse connected up
then had a think out how i was ging to perminantly connect up the gearbox end and so i made these
then another idea poped into my head i need to be able to tell the electronics what gear im in for my boost controller and data logging so
i fitted some magnets into the end so now i need to make another braket to fit the sensors to Smiley
then filled the hole up i made when i was going to us shift rods Smiley
cheers andy
Andy Sykes
« Reply #193 on: May 30, 2012, 17:45:32 pm »
little more done fine tuning realy had to do a slight mod to the end of the shifter rod as it was hard going adjusting the length of the shift rod
little test of the shifter Smiley
cheers
Andy Sykes
« Reply #194 on: May 31, 2012, 17:19:58 pm »
bit more done today making a few more parts and setting up and know at last the box is shifting fine and seams to be working fine its only taken me over 40 hours to do lol
all done Smiley
got a small mount to do this end but that will be done when i build the car Smiley
for those interested the bussiness end the last rod is reverse
cheers andy
Andy Sykes
« Reply #195 on: June 02, 2012, 12:46:51 pm »
so on to some electrical 1st fix today to work out where cables will run and and where i need to cut throuh the bulk head to run cables once ive done this it all comes out again ready to paint
cameras
gps
Dash2 and nitrous controller
got to find a home for these Smiley
its starting to come togther i think at last
cheers andy
Basti
« Reply #196 on: June 04, 2012, 04:58:58 am »
hi Andy!
are you sure that the GPS is working like
this?
cheers, basti
- black 62 cal look beetle
- Pro Mod Race car
Andy Sykes
« Reply #197 on: June 04, 2012, 08:27:17 am »
Hi I'm hoping it will be fine as its under the ragtop so should get a signal ok  Smiley
Cheers andy
Andy Sykes
« Reply #198 on: June 06, 2012, 19:11:54 pm »
Bit more done
This is to stop the wheelie bar mount flexing as the box is mounted to it Smiley
Cheers andy
Andy Sykes
« Reply #199 on: June 13, 2012, 16:17:13 pm »
So as I'm waiting for a few parts to continue,thought I would make a start on its transport
Found the on eBay prototype body that the car will JUST fit in Cheesy
Wheel arches will be coming out
So on with the chassis 6 lengths of 75 x 75mm box section
Transit rear axles need widening I'm also going to put them on air so hopefully I will be able to sit the trailer nearly on the floor Smiley
I'm going to remove these and get them re-drilled to adifferent pcd maybe 5x130 on put some Porsche wheels on there Smiley
Cheers andy
« Last Edit: June 13, 2012, 16:37:13 pm by fast65 » Logged
Andy Sykes
« Reply #200 on: June 14, 2012, 17:51:05 pm »
weldathon today 8 hours of cutting and welding and its 80% welded up just got to find some air bags so i can start on the axles Smiley
cheers andy
Wout
« Reply #201 on: June 14, 2012, 21:01:32 pm »
Nice one  Shocked Shocked
Is it streetlegal? In Belgium it's not legal to make a trailer over 750kg.
gr
Wout
Aircooled vw's for life!
Andy Sykes
« Reply #202 on: June 14, 2012, 21:23:44 pm »
I can't find anything that says I can't we get away with a lot in the UK with cars, if the trailer is over 750kg it must be braked and have the correct sized hitch and have working lights and be road worthy correct tyres etc. I've got to try and keep the weight down as I will towing it with this  Smiley that comes in at 6.25 tonnes
I can go to a total train weight of 8.25 tonnes on my car license if I go over a have to take a HGV test  Roll Eyes
Cheers andy
Andy Sykes
« Reply #203 on: June 15, 2012, 14:57:57 pm »
all welded up Smiley no wonto the suspension Smiley
part of a Russian rebreather
To#¤ta air suspension
getting there Smiley
cheers andy
dannyboy
« Reply #204 on: June 15, 2012, 19:40:30 pm »
sry mate but 2x1 pine will not be structually sound  Roll Eyes
 Grin
8.77@156.8mph
O/FF 60
Wout
« Reply #205 on: June 15, 2012, 20:36:54 pm »
Have to move to the UK  Grin
In Belgium you can't do a thing Angry Angry
Good luck, nice trailer!!!
gr
Wout
Andy Sykes
« Reply #206 on: June 15, 2012, 22:26:59 pm »
gr
Wout
Are you sure have you seen how much our VAT is and how much we pay for fuel lol
Cheers andy
Andy Sykes
« Reply #207 on: June 15, 2012, 22:28:11 pm »
 Grin
Lol there's me thinking I had over engineered it again  Roll Eyes
Andy Sykes
« Reply #208 on: June 18, 2012, 17:39:01 pm »
bit more done doesnt seem much but this thing is starting to weight a ton lol
axles welded up i think that is solid Smiley
thought i would strip these parts off so i can re drill them 5 x 130
but they seam to like it were they are, the gas bottles are coming out TMW
simple level control for the air ride there will be some more added to i can tilt the trailer and lift two wheels off the floor to help with turning the trailer Smiley
cheers andy
Andy Sykes
« Reply #209 on: June 19, 2012, 19:25:11 pm »
Spent all day getting these brakes apart ford crap lol
Two came apart and two did not
Even with ten tonnes on all that happened was the discs shattered Sad all because of this
Good news is I can get the 5 x 130 pcd in Smiley
Big ass NATO hitch arrived good for 3.5 tonne slightly over the top lol
Cheers andy
