September 10, 2026, 12:36:36 pm
Bad Habit
Brake mastercylinder on racecar
Topic: Brake mastercylinder on racecar (Read 4296 times)
Basti
November 20, 2011, 15:47:01 pm »
Hi Guys,
my racecar has a stock mastercylinder with drumbrake in front
and willwood disks at the rear and I am not happy withe the brake preassure.
Has anyone the same setup? Which mastercylinder are you using?
Udo told me about one from the 944 but he donīt have a partnumber...
Thanks for your help!
Basti
- black 62 cal look beetle
- Pro Mod Race car
Svwerker
Re: Brake mastercylinder on racecar
November 20, 2011, 16:30:47 pm »
You get higher pressure with a smaller diameter mastercylinder.
November 20, 2011, 17:09:31 pm »
The problem is not the higher pressure but the volume . We had the same when using the small racing calipers. You need more diameter to get more volume to each brake.
22 or 25 mm on the master cylinder. I have now 19 for the original front brakes and 24 on the rear for the aluminium calipers . That works perfect. The master cylinder is from a 944 Porsche but i do not know the part number and model
www.Udobeckertuning.de
