November 03, 2026, 17:46:28 pm
Jaycee oil control system
Topic: Jaycee oil control system (Read 4981 times)
November 21, 2011, 13:36:08 pm »
hello guys,
does anyone have experience with this system?
I suppose i can just install a HP1 style filter?
I have a problem with low oil pressure when hot,
so now i d like to get rid of the stock relief piston/spring,
and see if it solves my problem.
this is about the last thing i can check on the motor.
oil clearances were good, no gap between pump cover and pump, thick oil, booster springs and still only 0.4 -0.5 bar at idle (hot)
cheers, Peter
Jesse/DVK
'64 2176cc
Re: Jaycee oil control system
November 21, 2011, 13:41:34 pm »
Did you block off both the case and pump for full flow?
November 21, 2011, 13:43:35 pm »
YEP!
