October 13, 2026, 03:35:29 am
| | |-+  Weber 48 IDA frozen shaft...
Author Topic: Weber 48 IDA frozen shaft...  (Read 9158 times)
El Dub
Nostalgia VW addicted!
« on: November 27, 2011, 14:30:18 pm »
I was hoping to rebuild one of my Bologna IDA but things look not so easy... Well, the shaft is frozen. I let the carb in W40, try quite everything smoothly but I'm afraid to make things bader as they are now... Any ideas??? Can I push on the butterflies??? I think not???
« Reply #1 on: November 27, 2011, 18:28:43 pm »
Heat?
El Dub
« Reply #2 on: November 27, 2011, 18:46:45 pm »
I will try that ASAP, but I was afraid heat would bend the shaft... !!! Huh
OC1967vw
« Reply #3 on: November 27, 2011, 19:34:33 pm »
have you taken a 48IDA apart before? This is an early 48IDA1 or 48IDA4 with the 4 digit serial number? Unless you have taken one apart before, I recommend a Weber expert.
Brass butterflies must be removed first or you will damage them. Corrosion on the jet stacks or venturies (both main or auxiliary-a white crud)?
Sounds like possible corrosion/rust between the throttle shaft and inner surface of roller bearing housing (either end)-possible but unlikely-
or a rusted bearing (rusted ball bearing that you can see?)-very likely-bearing will not rotate
You need an experienced weber expert.
« Last Edit: November 27, 2011, 19:41:33 pm by oc67vw » Logged
« Reply #4 on: November 27, 2011, 19:43:41 pm »
If in doubt, send them to Art Traen   http://www.aircooledengineering.com/  They´ll know what to do.
El Dub
« Reply #5 on: November 28, 2011, 10:43:24 am »
Thanks guys! I will consider an expert as I am wondering how to remove butterflies with a frozen shaft that won't rotate... I suspect the bearings too....... I'll keep you posted...
Ninho/DKM
« Reply #6 on: November 28, 2011, 12:28:32 pm »
Before to ship it try to put the carb in a Diesel gas can for few days and after first day try to rotate the axle, if those bearings are freezed they will smoothly start to rotate. you could even try with white petroleum that will be good for carbs body renewal too but Diesel will works better.
1974 Superbeetle Porsche affected and influenced
1957 Gasser Project work in progress
1973 Thing type 181 Civil version (sold)
1959 Bug waiting attentions
1963 Surfin'Bird Street and Strip race Bug 1776cc Best E/T 14,769 at Hills Race#10
www.Surfinbirdbug.blogspot.it
www.Ninho-Reloaded.blogspot.it
OC1967vw
« Reply #7 on: November 28, 2011, 21:59:15 pm »
email Art or Pierce Manifolds-if you are in europe, there are weber experts in england. you have brass screws (you havent answered any questions on the condition of the carb) in the throttle plates. Brass is a very soft metal. Trying to do it yourself when you have never done it before (presuming) you risk damaging the original screws and the brass throttle plates-plates are replaceable/the screws are not.
The shaft bearings are press fit into the carb housing (both ends) and on end of the shaft. They normally do not move on the shaft as the assembly moves together. The ball bearings in the bearing assemblies that are in the carb housing are likely rusted and corroded and are frozen: that means the shaft assembly through the carb housing will not turn because the ball bearings in either or both of the bearing assemblies pressed into the carb housing are rusted/frozen solid (take off the small round plate on the shaft end that covers each of the bearing assemblies that are press fit into the carb housing: you should be able to see and determine the condition of the ball bearing assemblies).
Send it to John Maher or the weber experts in the UK
« Last Edit: November 28, 2011, 22:16:42 pm by OC1967vw » Logged
OC1967vw
« Reply #8 on: November 28, 2011, 22:00:08 pm »
Rubbish
OC1967vw
« Reply #9 on: November 28, 2011, 22:25:26 pm »
http://www.webcon.co.uk
« Last Edit: November 28, 2011, 22:27:35 pm by OC1967vw » Logged
Ninho/DKM
« Reply #10 on: December 21, 2011, 03:26:04 am »
Hey! You're do nice. Who are you a webcon employee? I was trying to help him with contructive words. Me not you.
CiaoBello.
OC1967vw
« Reply #11 on: December 21, 2011, 06:58:45 am »
CiaoBello.
Webcon is the leading Weber parts supplier specialist in the UK. There are specialists in Europe especially in Italy. All you have to do is the research or call them. If Webcon cannot rebuild it, they have specialists who can.
A frozen throttle shaft is a serious situation. It most likely is a frozen thottle bearing and that is a serious matter.
OC1967vw
« Reply #12 on: January 06, 2012, 20:05:29 pm »
Did you ever get it repaired?
