November 04, 2026, 13:05:42 pm
Pics of DDS linkage with Magneto on street engine
Topic: Pics of DDS linkage with Magneto on street engine (Read 6449 times)
guillaume
November 30, 2011, 22:04:25 pm »
Hello,
Could you help me ? I am looking for pictures of DDS Deano linkage (or new Bugpack swivel linkage) with 48 ida, Fan and magneto.
I am having some trouble to use mine. Maybe I will be to modify something ?
Thanks for your help guys
Re: Pics of DDS linkage with Magneto on street engine
November 30, 2011, 22:25:05 pm »
What kind of trouble are you having?
Maybe you could post a photo ... ?
TxT
guillaume
November 30, 2011, 23:11:18 pm »
The rod and the linkage part will touch the cap of the dizzy or the body of the magneto (see the red marks made on the photo).
I thought about monting the rods with a push/pull instead a pull/pull.
November 30, 2011, 23:34:35 pm »
I think you have the center mount bolted to the case backwards!
Then the spindle will be much closer to the generator and not behind the distributor/magneto and the cable will attach on the opposite side, and your linkage arms will balance out better ... threaded in more on the right and less on the left side ... even.
Try that and see what goes on ...
TxT
guillaume
November 30, 2011, 23:57:01 pm »
Thanks Tom
I will do that and see if it works.
December 01, 2011, 00:12:46 am »
Lookin' GOOD, by the way ...
December 01, 2011, 01:48:18 am »
I think he has the linkage base correct, check out the photos John L posted of Tar Babe...
Frenchy Dehoux
December 01, 2011, 03:33:28 am »
The base is on correct I had the same issue with my 1835 and I had to put a small spacer under the main swivel to have it space upward so that the linkage would not hit the distributor cap.
Frenchy
Doctor Detail ( Retired )
Fritter
December 01, 2011, 07:05:25 am »
They say to hook the pedestal rods up from the bottom, but on my Deano DCN kit I had to attach the left rod on the top of the pedastal pivot so as not to hit my 019 disty's cap.
Mike F.
'64 Indigo Blue sunroof Bug
December 01, 2011, 17:37:03 pm »
guillaume have the same with my racetrim
http://cal-look.no/lounge/index.php/topic,13741.msg206041/topicseen.html#msg206041
, but now it's on the engine like yours and no trouble
