October 12, 2026, 12:42:47 pm
67 ragtop, quick project
Topic: 67 ragtop, quick project (Read 61240 times)
karl h
Re: 67 ragtop, quick project
Reply #30 on:
January 25, 2012, 08:32:50 am »
dash is finished
had some fun wiring a two speed 12V wiper with switch to the stock actuators, but managed with the help of some colourfull words
i mounted the stereo into the glovebox (remember, this is a driver), so its completely hidden. the tweeters will be mounted under the headliner, just adjacent to the sonroof, the woofers (also hidden) in the doors. i just dont like the looks of speakers cut into the doorpanels, it just doesnt look period correct
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #31 on:
January 25, 2012, 08:36:03 am »
an old sun tach will get mounted under the dash, i think the monster tach looks a little bid stupid combined with a stock 1600
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
thehanz DVK
Reply #32 on:
January 25, 2012, 19:36:55 pm »
good progress looks nice , like the idea for the tweeter out off sight
Reply #33 on:
January 26, 2012, 01:24:21 am »
Hmmm those tack welds on the sunroof corner braces are going to make the headliner installation tricky!
karl h
Reply #34 on:
January 26, 2012, 07:35:45 am »
thanx hans. i do know i cant install the headliner like on a sunroof that came stock, but i have a solution i have tried before. stay tuned
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #35 on:
February 28, 2012, 12:06:06 pm »
due to real life issues i have not been able to work on the 67 as much as i wanted
some work got done though, the front beam is assembled, i just have to rebuild the calippers. i used my sprintstars to get the car rolling again because there are tires on them (155/70 michelins)
Last Edit: February 28, 2012, 12:09:01 pm by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #36 on:
March 06, 2012, 09:28:57 am »
temporary engine is in (1600 with homemade 30hp shroud, type 4 doghouse cooler)
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
thehanz DVK
Reply #37 on:
March 06, 2012, 20:45:40 pm »
getting nearer keep up the work
karl h
Reply #38 on:
March 09, 2012, 08:23:59 am »
i will try
front fenders temorarily fitted to reconstruct front wiring harness
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #39 on:
March 27, 2012, 11:15:59 am »
i finally found the time to do the headliner
i constructed a custom middle part [ Attachment: You are not allowed to view attachments ] to be able to cover the part above the windshield
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Reply #40 on:
March 27, 2012, 14:03:08 pm »
Where did you get the 155/70's?
Reply #41 on:
March 27, 2012, 14:24:22 pm »
aren't those available in the US, zach? they're a 135r15 but 2cm wider, pretty cool tyre i think.
DVK ~
karl h
Reply #42 on:
March 27, 2012, 16:42:31 pm »
bought them off ebay some time ago, merceds A-class had these stock
Last Edit: March 28, 2012, 06:46:22 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #43 on:
March 30, 2012, 10:43:26 am »
next i started on the sunroof assembly. my colour choice was a medium grey TMI cover (thanx to dave conklin for ordering it for me). since the runningboards are supposed to be lead grey on fontana grey cars this should fit nicely. i may cover these in a similar material. all of the sunroof mechanics were disassembled, cleaned and the missing rolers replaced. the headliner piece is tricky to mount, if you do it be sure to keep the original one for measurements, even if only fragments of it are there
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
qubek
Reply #44 on:
March 30, 2012, 11:14:41 am »
Quote from: Zach Gomulka on March 27, 2012, 14:03:08 pm
Good question. If I understand correctly, Michelin makes a batch from time to time and the last one was probably something like two years ago. I need to replace mine, because they are old, and I cant find any. I have contacted several companies that lists them on their pages, only to be replied that they are out of stock.
A pity, because it is a very convenient size for a cal-looker IMO.
red baron
Reply #45 on:
March 30, 2012, 11:19:02 am »
There is a Vredestein kind of winter tire many european stock cars have. But the profile isnt really pretty.
http://www.oldtimerreifen24.de/shop/produkt-ansehen/reifen-kaufen/155R15_Q_Vredestein_Snow_Plus.html?cHash=0dfae2631b
qubek
Reply #46 on:
March 30, 2012, 11:29:53 am »
It's 155-15 , not 155/70-15
And this is a strictly winter tire.
karl h
Reply #47 on:
April 02, 2012, 08:06:42 am »
the ragtop is on and the headliner pretty much finished
since the original cardboard was rotted on the lower edges, i cut some doorpanels from hardfoam material. the speakers were cut into them, but will not be seen once the original vinyl will be glued on.
Last Edit: May 30, 2012, 11:02:23 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Cornpanzer
Reply #48 on:
May 08, 2012, 14:43:40 pm »
Update pls?
'67 Turbo Sedan
Ultra VW Contributor
christ4
Reply #49 on:
May 08, 2012, 15:31:07 pm »
look here:
http://www.fritzreifen.de/pkw/sommer/155/70/15/2874/energy-xt1?sPartner=googleFR
karl h
Reply #50 on:
May 09, 2012, 06:54:36 am »
i have assembled the doors and put in the carpet. a lot of time was spent hunting down a zillion little pieces that are either missing or in too bad of a condition to be used.
only crappy cellphone pic, sorry (this will be my last blackberry)
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
thehanz DVK
Reply #51 on:
May 11, 2012, 15:58:34 pm »
good progress Karl, this will be on the road this summer i think, looking good, the quicker version off my bug, so needles to say i like it
karl h
Reply #52 on:
May 29, 2012, 07:26:18 am »
hey hans, you can only mean finished earlier, this thing wont be quicker than anything with its stock 1600
some progress i made this weekend:
mounted the rear fenders. the 5.5 sprintstars with 195/65 are too wide, so i will stick with the plan to use BRMs and 165/80s in the rear
kinda like the ansa endpieces i made out of an old dual endpiece, they
look
fast at least
and no - i´m not going to use the crappy airfilter, its just on there to keep junk out of the carb
Last Edit: May 30, 2012, 11:04:08 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #53 on:
October 15, 2012, 07:07:26 am »
well its been a while, got sidetracked with construction work on the garage, so nothing happened for all of summer
i did a kind of rollout today to dust it off. i still have ti find the electrical bug, the cluth pedal is much too soft
and there is all kinds of little stuff. i have to find rear tires for the BRMs that will go on and the front hood doestn fit right. maybe i can modify the hinges, but may have to cut the front apron off and reposition it
. its a replacemant panel that came on the car and i was too stupid to ckeck the fit. havent adjusted the ride height yet either....
i know it will be finished when theres half a meter snow outside
cant upload pics, its says the upload folder is full
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Reply #54 on:
October 16, 2012, 11:01:07 am »
some pics
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
thehanz DVK
Reply #55 on:
October 16, 2012, 15:53:44 pm »
looking good Karl....
this car needs a dual quiet pack, this exhaust doesn"t do right to the car, but good progres
karl h
Reply #56 on:
October 17, 2012, 06:53:04 am »
thanx! funny that you mention it, i also thought about a quiet pack...
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Cornpanzer
Reply #57 on:
October 23, 2012, 13:03:08 pm »
looking really good!'
'67 Turbo Sedan
cedric
Reply #58 on:
October 24, 2012, 08:11:47 am »
Nice work..
karl h
Reply #59 on:
January 18, 2013, 08:33:21 am »
long time no progress, but now the wiring is done, BRMs are on and its lowered in the front
difficult to take pics in the garage and outside there is lots of snow
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
