November 04, 2026, 15:15:26 pm
352339 Posts in 28963 Topics by 6931 Members
| | |-+  What front disc brakes kit to use with 13 inch DDS wheels ?
Author Topic: What front disc brakes kit to use with 13 inch DDS wheels ?  (Read 5886 times)
guillaume
« on: December 05, 2011, 01:44:05 am »
Hi,
Do you know what kind of front disc brakes should I buy to use my 13 inch DDS wheels in 5 x 205 ? I will use them with drop spindles. But the caliper on the dis will probably touch the wheels. I have no idea yet but maybe some of you already used 13 inch wheels with disc ?
Thanks for your help guys Smiley
« Reply #1 on: December 05, 2011, 02:53:23 am »
That's asking a lot from a 13" wheel. First I would make sure a drop spindle with drums will fit, and go from there.
« Reply #2 on: December 05, 2011, 07:26:27 am »
Yeah... I dont think you'll clear drop spindles with a 13in wheel.
Some 15 in wheels don't clear drop spindles without a little clearancing.
« Reply #3 on: December 05, 2011, 08:46:54 am »
14" alloys, will not work with drop spindles, 13", I really doubt it. Maybe reg. disk spindles might work.
Ted
Bendik
« Reply #4 on: December 05, 2011, 14:37:46 pm »
I knew discs and 14" didn't match, but is there a problem with the dropped spindles as well?
« Reply #5 on: December 05, 2011, 16:31:02 pm »
one solution  guillaume : spindle mounts like drag car  Grin Grin
guillaume
« Reply #6 on: December 05, 2011, 21:33:24 pm »
-Alex-
« Reply #7 on: December 06, 2011, 23:36:30 pm »
If you want  discs for 13" wheels with 5x205 pcd, how about custom brakes? 10" Wilwood rotors, aluminum hubs, moving the stock caliper closer to spindle center etc. If its a race car, parts doesnt have to be street legal, they can be custom made.  Other choice is drums  Grin
http://www.wilwood.com/Rotors/RotorList1.aspx
This is just a quick sketch Smiley
hotrodsurplus
« Reply #8 on: December 07, 2011, 09:48:24 am »
Ted
I wonder if the same holds true with the DDS wheels. The alloys have a LOT of positive offset so the wheels completely wrap around the brakes. The DDS wheels on the other hand have negative offset. There might be sufficient clearance with the DDS wheel.
Do you absolutely have to have dropped spindles? If it's a kingpin car you can get a low stance and stock-feeling ride quality by pulling leaves. On my '62 I installed the adjusters as if I was going to raise the car. With the adjusters all the way down I started pulling leaves until I got the lowest ride height I would use. I cut the ends and centers from the pulled leaves and brazed them to the remaining leaves so the set screws would capture the springs properly.
I can raise the nose to nearly stock height. I run stock-style Cofap dampers and the ride is incredible. Twin-trailing-link suspension has inherently poor handling and braking qualities so there's little reason to miss them if they do suffer. I've run that same setup since 1988 with very positive results.
I've done it to ball-joint cars but you can only lower the suspension about 1 1/2 inches before ride quality suffers. But then again if you're running a 13" DDS wheel chances are you are not going to build a poser pan scraper anyway.
