October 13, 2026, 18:42:47 pm
| | |-+  show us your cal look 65-66 bugs
Pages: 1 2 [3] 4 5 ... 7 Print
Author Topic: show us your cal look 65-66 bugs  (Read 129521 times)
« Reply #60 on: February 26, 2009, 03:15:19 am »
Up until last year, Alan's gearbox used a 4.12 O type R&P with a stock 9 tooth mainshaft and 1.58/1.22 Weddle gears.  The superdiff used 10/15 gears, all in a late case and SAW axles.  With this he ran into the 11s and did those wheelies.
His latest gearbox uses a G type 3.88 R&P and a 4.11/2.47 Weddle mainshaft, with 1.65/1.31 gears.  A Q replaced the superdiff.
roland
lates are the new splits...
« Reply #61 on: February 26, 2009, 14:47:29 pm »
My old 66 bug a before and after shots.
Looked great! shame it was crashed...
« Reply #62 on: February 26, 2009, 21:16:57 pm »
Yes it did, I swapped last season. I wanted good disc brakes without all the weight and cost of CSP brakes. I run original VW rotors drilled for the Porsche pattern and BMW 2002 calipers.
Hi,
Could you tell me a bit about the turbo set up,
Looks neat
48IDA66
« Reply #63 on: February 26, 2009, 22:05:13 pm »
My 66 steel sunroof on original burners.. Wink
beetletom
« Reply #64 on: February 26, 2009, 22:17:45 pm »
thats awesome!!!  Cool
48IDA66
« Reply #65 on: February 26, 2009, 22:32:08 pm »
Thanks beetletom, has run the roads  for the past 10 years!.. Wink
67worshipper
« Reply #66 on: February 26, 2009, 22:37:26 pm »
thanks bruce.are these pro drag equivalents? it must be with weddle gears.
vw hot rod heaven
Dez
Grey Anatomy
« Reply #67 on: February 27, 2009, 00:16:36 am »
My 66 RHD erm 'Looker' at the moment, hopefully to be finished by June '09
bugkeeper
oldskool n numetal
« Reply #68 on: February 27, 2009, 12:23:12 pm »
Hi,
Looks neat
Hello Lee thanks a lot, the setup is a A.J. Sims Turbo setup which I am really happy Cheesy about. No matter what others might tell you, I am very happy with the knowledgeable help and the workmanship of these Turbo systems.
It is a T3 Turbo paired with a Holley 350 carburetor plus a Mallory HyFire ignition with map sensor and boost retard. It is a blast to drive!  Grin
Cheers Dom  Cool
« Reply #69 on: February 28, 2009, 09:28:16 am »
No, his gears are all pure street gears with stock synchros.  'cause his car is a STREET car, not a race car.  That's why he took the huge weight penalty with a Quaife over a spool.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #70 on: February 28, 2009, 13:59:40 pm »
Sorry foor the terrible picture quality
« Reply #71 on: February 28, 2009, 17:12:53 pm »
Hi,
Looks neat
Cheers Dom  Cool
Hi Dom,
Thanks for the info. Like the look of the kit. Are you using the 1600T kit? What times you run with it on the motor (spec)?
I have a mild 1776cc that would respond well to that.
bugkeeper
oldskool n numetal
« Reply #72 on: February 28, 2009, 17:39:01 pm »
Hello Lee, I have two engines, one was used to get the car street legal in Switzerland, the other is my street/strip motor. The motor I used for getting the car legal is a 1600cc engine with small FI heads with only 32x30mm valves. I installed a Webcam 119 and dual valve springs and chromoly pushrods. That is it... with only 0.4 bar (5.6 PSI) boost it delivered a whopping 121 HP at 5100 rpm. The quarter mile time leaves room for improvement I ran 15.06 with street tires, 8 PSI boost and a whopping 2200 pounds total weight. I weigh 310 lbs myself.... I know I should go on a diet. Currently I am loosing weight for the upcoming season... It is very nice to drive, but I am going to replace the cam with a webcam with an original VW grind. This will the rpm range to below 5000rpm and make the turbo more responsive.
My engine for this coming season is a 1915cc with piston squirters, the proper LBC2 cam and a better ignition system. I hope to scratch the 200HP mark with a bid more boost...this and a little less weight should improve my quarter mile time this year.
Your 1776 will love the turbo treatment. Just keep in mind not to over cam your engine and keep the CR low. 7.5:1 will do.
Cheers Dom Cool
yvre
Der Autobahn Scrapers
« Reply #73 on: February 28, 2009, 19:16:13 pm »
More pics please!
48IDA66
« Reply #74 on: February 28, 2009, 22:02:18 pm »
yvre,
What did you like to see?...
(and thanks to terovirta.com for the fotos)... Wink
« Last Edit: February 28, 2009, 22:13:34 pm by 48IDA66 » Logged
67worshipper
« Reply #75 on: March 01, 2009, 12:37:51 pm »
thats pretty cool bruce.those wheelies are awesome.is it solid mounted then?
vw hot rod heaven
« Reply #76 on: March 01, 2009, 14:29:12 pm »
Some shots of Henry Oelkers' '66.... Cool
« Reply #77 on: March 01, 2009, 16:28:36 pm »
nice pict bro  Shocked
Dez
Grey Anatomy
« Reply #78 on: March 01, 2009, 17:09:51 pm »
Agreed  Shocked I can't wait to drive mine now  Undecided
« Reply #79 on: March 02, 2009, 20:40:55 pm »
Thanks guys! Wink
« Reply #80 on: March 02, 2009, 21:07:25 pm »
what a beauty! love the interiour very much.
i saw a very small picture off this car in a lineup shot in VWTrends and i didn't know who's car it was, but i liked it and have grown to like it more and more after seeing more detailed pictures afterwards.
IP359
« Reply #81 on: March 02, 2009, 22:30:05 pm »
Please Sarge, don't hesitate to add more pics of this beauty.....
Thanks in advance
67worshipper
« Reply #82 on: March 02, 2009, 23:38:34 pm »
i like henrys car as well  Cool as
vw hot rod heaven
« Reply #83 on: March 03, 2009, 03:09:53 am »
Yes, it's solid mounted.  He only uses a rear engine support bar and a forward trans mid mount.
Tony Wilkie
« Reply #84 on: March 03, 2009, 03:40:07 am »
I miss my 66   Cry
tw
Operations Trask Manufacturing
Design, Prototype, & Dyno Tune Custom Motorcycle Exhaust
« Reply #85 on: March 03, 2009, 11:12:34 am »
That's a really cool stance Tony! What happened to it?
Tony Wilkie
« Reply #86 on: March 03, 2009, 17:21:58 pm »
Sold...shipped to Asia.
I have a few other projects in the works  Wink
tw
OgCalLook
Straight outa Riverside!
« Reply #87 on: March 17, 2009, 23:33:58 pm »
My 66 - 356 rims - New pic
Tom Hewitson
Bahama Blau Kafer
Zach Gomulka: "California Look is walking softly and carrying a big fucking stick."
tomi g
« Reply #88 on: March 18, 2009, 00:04:40 am »
mine is not very cal-look but '66
ChuckyBug
« Reply #89 on: March 18, 2009, 10:55:49 am »
Hi Guys,
just wanna show you my faded out '66...
Hope to see more action on the track this year.
Pics stolen from Andi/DFL, OlafA/DFL
hang loose,
Markus
hang loose
