November 02, 2026, 21:11:39 pm
| | |-+  enlarging cylinder bores
Author Topic: enlarging cylinder bores  (Read 7524 times)
Fast Eddie
« on: December 08, 2011, 00:30:47 am »
How much should I expect to pay to have a set of 94mm type 4 barrels bored to 96mm?  Any ideas?
Tobi/DFL
« Reply #1 on: December 08, 2011, 08:39:59 am »
Hi Eddie,
club mate Otto and me asked some companies to bore some 94mm Type 1 mahle cylinders to 95mm and got quotes of ~60€ per cylinder incl. the honing.
Tobi
Basti
« Reply #2 on: December 08, 2011, 10:44:24 am »
That is cheap!!
- black 62 cal look beetle
- Pro Mod Race car
« Reply #3 on: December 08, 2011, 11:06:14 am »
How many minutes would a 96 mm mahle stay round? Or is it hours?
« Reply #4 on: December 08, 2011, 12:24:53 pm »
AJ Sims sells thick wall 94's,
maybe it can work?
« Reply #5 on: December 08, 2011, 12:25:56 pm »
This is a road well traveled on type 4's, is it not?
« Reply #6 on: December 08, 2011, 13:39:45 pm »
My mistake, I missed the point about type4... I was thinking about type 1.
I will show myself out Roll Eyes
« Reply #7 on: December 08, 2011, 14:43:22 pm »
A little off topic, but I've been wondering if a 96 bore could be shoehorned into a type one, reliably. Standard heads, of course. Gives you 2 liters without stroking!
Fast Eddie
« Reply #8 on: December 08, 2011, 18:11:44 pm »
thanks for the replies guys. i have had a quote in the UK and it was £60 each cylinder. so not too far out then. thanks again. Smiley
Arnoud
« Reply #9 on: December 08, 2011, 23:10:56 pm »
Armin Klein(TurboBoxer.de)charges 300Euro to bore/hone your barrels to 95mm.
Dr P.
« Reply #10 on: December 23, 2011, 19:49:33 pm »
What is the standard procedure to bore the cylinders? I always thougth they were bored like inline engines, but then I saw a video where Harley cylinders were "bored" on a lathe and then honed the usual way. In case someone has done it on a lathe it would be nice to know what bits to use at what speed. I have a set of 90mm that will grow to 90,5 at some point to accomodate low crown type1 pistons. Since they need to be shortened anyway it would be convenient to also bore them on the lathe.
GetBackOnTrack
« Reply #11 on: March 24, 2012, 11:50:45 am »
I bore cylinders in a special made jig in the lathe and hone them afterwards on my sunnen hone machine..
I charge 300 euroes for 4 cylinders...
Check out GetBackOnTrack on facebook for info about the machine work I do, and feel free to contact me if you need any work done.
Regards, Jakob Spring (GetBackOnTrack)
Check: gbot.dk
