September 14, 2026, 04:54:13 am
Latest Member: Bad Habit
| | |-+  Magneto advance curve rework in Europe?
Author Topic: Magneto advance curve rework in Europe?  (Read 4239 times)
181
« on: December 09, 2011, 13:36:48 pm »
Who can do it? I have an excellent industrial magneto which I wouldl like to use on my engine. Who can change the advance curve to "Bosch 010" style and recharge the magneto elements?
Thank you,
Jan
« Reply #1 on: December 09, 2011, 14:06:25 pm »
I overheard Ian Clark@Wolfsburg Perfornance saying he had a contact who could work on magnetos.
May be worth contacting him.
hotrodsurplus
« Reply #2 on: December 10, 2011, 10:24:39 am »
the scintilla-type mags have a slightly different style advance mechanism than most conventional distributors do. They use stacked brass weights and not a counterweight and springs. They typically don't offer a lot of fine tuning--mostly the amount of advance is important than the rate at a given engine speed. The advance is there so the engine can start. Once it fires the advance usually kicks in fully very quickly. That's not altogether bad for a performance engine.
 Airplanes use mags so ask around small airports who energizes magnets. small local private shops will often do the work very inexpensively if you disassemble the mag. Are you sure yours needs magnetizing?
You can get all the tools you need plus a real good book on how to work on vertex-scintilla mags at speedwaymotors.com
