October 13, 2026, 22:34:50 pm
How many times did you find a crushed flywheel o-ring
Topic: How many times did you find a crushed flywheel o-ring (Read 13565 times)
December 16, 2011, 01:31:45 am »
Racers, i'm crushing o-ring after o-ring when mounting the fly-wheel. No matter what i do, heat, lubricant, etc. Common problem? It's driving me nuts. What are youre experiences ?
Harry
Re: How many times did you find a crushed flywheel o-ring
December 16, 2011, 02:04:35 am »
what brand o ring? and what brand flywheel? can you show us what it looks like still in the flywheel groove after you took the flywheel off?
cheers richie
Jesse/DVK
'64 2176cc
December 16, 2011, 11:55:35 am »
Maybe a stupid question, but how do you notice a crushed O-ring? End play which increases?
December 16, 2011, 12:35:09 pm »
Quote from: Jesse/DVK on December 16, 2011, 11:55:35 am
Jesse, i found this out when turning the flywheel, after enplay is set, i would get different readings on my dial.
Pics, later.
Harry
December 16, 2011, 12:36:57 pm »
Quote from: richie on December 16, 2011, 02:04:35 am
cheers richie
Thanks Richie. Victor-Reinz 0-ring, german flywheel, pics will follow. I have a hunch what causes the problem...
Berger
www.bugrent.no
December 16, 2011, 14:34:05 pm »
I think you have to smooth the edge on your crankshaft. It`s probably too sharp and "grabs" the o-ring when you mount your flywheel.
This is my simple religion:
-Be cool
-Don't be an asshole
Jesse/DVK
'64 2176cc
December 16, 2011, 16:21:16 pm »
Quote from: Harry/FDK on December 16, 2011, 12:35:09 pm
Pics, later.
Harry
I know John CNC (mebejo) also modified my flywheel for the O-ring. Will take a pic of it tonight!
December 16, 2011, 17:58:47 pm »
Quote from: Berger on December 16, 2011, 14:34:05 pm
Thanks Berger, that was my first thought also. It's smooth.
December 16, 2011, 18:08:14 pm »
Quote from: Harry/FDK on December 16, 2011, 12:36:57 pm
cheers richie
Crankshaft end has a smooth radius, the flywheel however has been machined deeper on the o-ring side. On the bad pic you can see a small black dot on the bottom side of the o-ring groove. This section cannot mate with the crank perfectly so i think this is causing my o-ring problem, and gives me different readings for endplay when i turn the crank. Hope this makes sence.
Harry
PS, i checked some no brand o-rings today, most have "hairs" inside/outside that can cause many people the same problem.
Last Edit: December 16, 2011, 18:11:35 pm by Harry/FDK
Berger
www.bugrent.no
December 16, 2011, 18:48:26 pm »
Quote from: Harry/FDK on December 16, 2011, 17:58:47 pm
Do you have a picture of the crankshaft end?
-Be cool
December 16, 2011, 19:14:28 pm »
December 16, 2011, 19:55:03 pm »
Seems to me that the grove isn't at the very bottom of the flywheel?
Berger
www.bugrent.no
December 16, 2011, 21:20:19 pm »
I think it`s to sharp. Grind the edge so it`s completely "round", no angles. That`s my advice
-Be cool
December 16, 2011, 21:52:22 pm »
Quote from: JHU on December 16, 2011, 19:55:03 pm
Jon, i checked some other flywheels and the groove is never at the bottom. There's always that second step before crank and flywheel mate. Otherwise the o-ring cannot "seat".
Harry
December 16, 2011, 21:55:06 pm »
Quote from: Berger on December 16, 2011, 21:20:19 pm
Thanks Berger, i will.
Harry
Last Edit: December 16, 2011, 22:00:33 pm by Harry/FDK
dangerous
December 17, 2011, 07:46:30 am »
I agree,
and also, use the graphite coated O-rings like Elring used to sell.
The Elring USA ones that come in their gasket kits are horrible, not even round in section.
December 18, 2011, 01:15:46 am »
Ditto.
It's that sharp edge on the crank that's doing it.
Measure up an o-ring, then go to your local hydraulics store and buy some. The quality is vastly superior.
December 18, 2011, 01:53:38 am »
Quote from: Harry/FDK on December 16, 2011, 18:08:14 pm
Why? so are you saying that the flywheel was machined in the area the crank fits into deeper that normal? was the end of the flywheel machined to compensate for this? to keep the correct distance for end play.
If so the o ring is now moving further up the end of the crank when you fit the flywheel and trying to twist itself around,do you fit it with the crank end dry?a little oil would help,its not ment to sit up that far on the crank end in my opinion,be carefull if you "round off " the end of the crank to keep it even,I ave had no problems for a long while,just using the regular Elring supplied o ring that comes in ther gasket sets.
Hopefully you find the sloution and can finish up your engine soon
cheers richie
December 18, 2011, 20:53:54 pm »
Quote from: richie on December 18, 2011, 01:53:38 am
cheers richie
Richie, youre correct. The flywheel has been machined deeper because the balancer didn/t like the mating of both surfaces. Normally i had never a problem with Victor Reinz / Elring gasket sets with the 0-ring supplied. Enough boring you all, back to my other topic Get 'R Done.
Thanks again all.
Harry
PS, of course i lubrcate the 0-ring with in this case moly, teflon spray whatever.
Last Edit: December 18, 2011, 21:06:09 pm by Harry/FDK
