October 12, 2026, 12:18:30 pm
A 1915cc gets a makeover, Norwegian-style :)
Topic: A 1915cc gets a makeover, Norwegian-style :) (Read 25402 times)
December 28, 2011, 00:19:59 am »
In Norway we have a saying; "Mye vil ha mer" which translates to "Alot wants more" or something.
This is it: My "old" 1915cc wanted more grunt, so I decided to give it some treats
It was:
AS41
Mahle 94
G01 heads 35,5/32
10-1
web 109
1,25 rockers
stock rods
1,5" merged
40 IDF
lightened FW
OE crank
It's going to be:
AS41
Mahle 94
044 Wedgeports 42/37,5
11 to 12-1
Web 86c
1,4 rockers
5,4" CB H-beam rods
1 5/8" merged
48IDA with shortened manifold
lightened FW
DPR crank
The CNC'd heads will get a fluff and a buff and a healthy flycut. I'll try to get my deck height to 1,2mm, and a cc of around 35-40cc
Plan is to get 100hp pr liter at the FW.
Last Edit: December 28, 2011, 13:25:38 pm by bug66
fredy66
Re: A 1915cc gets a makeover, Norwegian-style :)
December 28, 2011, 13:09:01 pm »
I'm reading
arabia slugs
Jeff68
December 29, 2011, 15:22:40 pm »
Since the case will be split and you reference a DPR crank, are you going to increase the stroke? I would, either 78, or 82mm.....maybe more, whatever your budget allows. If you go to 82mm or greater it may be best to replace your connecting rods and of course, the case would have to be clearanced as well. Onward and upward! Best of luck with your engine!
December 29, 2011, 16:53:10 pm »
It's in pieces. I don't like the phrase "there's no replacement for displacement".. I'll just take it a 1000rpm's higher
No really.. It's staying as a sub 2litre
January 02, 2012, 08:37:14 am »
The rotating assembly was balanced in absolute "0" the past week. The DPR crank was good from DPR, but needed a little tweak to be 100% perfect.
The next step is to deliver the heads and manifolds to a buddy. He'll smoothen out the heads, buff and polish the exhaust port and shorten the manifolds.
The length of the manifolds will be matched to the engines characteristics using second order:
2.order: 3350000/rpm=manifoldlength in mm
3350000/8000 = 418,75mm
Did a quick check the other day and need to shave of 7-8cm!
Last Edit: January 02, 2012, 08:43:14 am by bug66
Olzzon
January 02, 2012, 15:58:09 pm »
Fun with a 1915cc building, I'm about to build on the same concept with almost the exact same parts as you. I will run with a FK89 cam but I think I will go down from the 1.4 rockers so I get clearance between the valve and piston. The biggest challenge is that said to get the compression yet have clearance.
But small-block engine is cool!
January 02, 2012, 16:41:45 pm »
Valve pockets ;-)
Olzzon
January 02, 2012, 17:30:41 pm »
Quote from: bug66 on January 02, 2012, 16:41:45 pm
Valve pockets ;-)
Yes I know, but the pistons is not how thick any time either
It is just to measure and see how much lift you can run when everything is installed simply
January 02, 2012, 18:50:13 pm »
Quote from: bug66 on January 02, 2012, 08:37:14 am
It was US balanced.
increase the sensitivity and you will find that it will still need work to get to a point where it is "true" 0.
January 02, 2012, 19:01:08 pm »
Quote from: Olzzon on January 02, 2012, 17:30:41 pm
Valve pockets ;-)
I was actually thinking of welding some of the chamber to raise the CR. We'll see how it will be.
January 04, 2012, 11:57:25 am »
Here you can see the mockup. and the LONG manifolds..
Modified the CB tower to allow more air to vent [ Attachment: You are not allowed to view attachments ]
January 17, 2012, 10:32:40 am »
A little hickup..
Checked end play with the crank at the bench with FW and a Silverline bearing.. All good, but forgot to check with the KS bearing that's in the engine now.
No in short shortblock with 0,41mm end play (w/o shims)
Need to modify the FW..
more to come
January 20, 2012, 11:28:04 am »
Got an update on the manifolds today
January 28, 2012, 22:07:04 pm »
Got my heads back yesterday. We spent 4 hours trying to get a reasonable endfloat. Ended up machineing bot the lip of the FW and the and the area that mates with the crank.
Heads and manifolds:
January 28, 2012, 22:10:48 pm »
Fredrik Grönlund
January 29, 2012, 21:56:25 pm »
Thank for good pictures on the shortened intake manifolds. We are going to do the same mod toghether with Pep.
How long are the intakes alone?
January 29, 2012, 22:26:32 pm »
You know what? I haven't meassured them after I picked them up. I guesstimate them to be about 12cm. Will check it tomorrow! They are nice! And will hopefully flow more than before :-)
January 30, 2012, 22:02:10 pm »
Fredrik: They are 14cm long
If you are planning to have large ports, I truly recommend to move the flange bolts furter apart. It is seriously tight.
Fredrik Grönlund
January 30, 2012, 22:12:22 pm »
Quote from: bug66 on January 30, 2012, 22:02:10 pm
Yes i have noticed that also that it is littlebit difficult to get enough room for the fastening bolts. I think i will use allen bolts instead of normal M8 nuts. With that it is possible to get couple of extra clearence.
January 30, 2012, 22:22:13 pm »
I can't even put the manifold on and then nuts. I need to enter the manifolds first, then slowly combine lowering the manifolds and tightening the nuts.
I even need to macine a set of CSP 10mm nuts. The collar needs to go!
But.. I'll probably get another million hp
The cool thing is that the manifolds are so short they don't stick further out than the heads, so it should be possible to get the engine in with manifolds mounted
cassa
January 31, 2012, 22:54:09 pm »
If you weld on the inside of the manifold to make the ports line-up with the heads, you get a little more room for the nuts. But shortening the way you did is not ideal. Lots of port work left I would think?
(been there ...)
January 31, 2012, 23:53:25 pm »
Did not get that last one.. Could you explain or post a picture?
March 02, 2012, 15:42:55 pm »
I've had way too much to do
but.. the engine is almost ready! only need to adjust the valves and top it up with oil. I'll start it and break in the cam etc in a bench before it's going in the car.
Also need to give the muffler a coat of high temp paint.
March 04, 2012, 11:18:08 am »
Congratualtions!! When will it go on the dyno?
March 04, 2012, 13:29:27 pm »
Plan was to bench-dyno it before it went into the car. But now I think it will be started in a bench, and then dynoed in the car.
I don't know who's got a bench-dyno ready in my area.
We'll see
March 04, 2012, 18:42:09 pm »
Why are you not using a power pulley?
March 04, 2012, 21:47:56 pm »
Need to be able too run it cool on the streets also
March 04, 2012, 23:00:18 pm »
Quote from: bug66 on March 04, 2012, 21:47:56 pm
Oh.. I forgot the warm summer we have in Norway and the crappy fuel quality. BTW, have you noticed all the VW trikes? They have become quite popular lately. Take a good look next time you see one and see if you can spot their fan house.
March 05, 2012, 00:19:23 am »
Haha. If I'm not happy with the power the engine produces with this pulley, I can try a power-pulley, get 10ish more hp and see how much hotter it gets.
BTW Kalle.. Is start up in your bench a alternative?
March 17, 2012, 23:08:56 pm »
http://www.youtube.com/v/CMpfEtVRIqs
