September 22, 2026, 09:32:43 am
| | |-+  Need assistance with clutch set up....
Author Topic: Need assistance with clutch set up....  (Read 3615 times)
c.v.helleri
« on: January 02, 2012, 19:36:34 pm »
     I recently trashed a Kennedy stage 2 plate, and I may have over done the adjustment.  When I removed the engine the disc wad just flopping around between the plate and flywheel.  I made sure the clutch adjustment was correct per the Bentley manual.  i'm at a loss as to what could have gone wrong....   Any insight will be appreciated so I don't make the same mistake twice....
« Reply #1 on: January 02, 2012, 22:02:40 pm »
Is the main diaphragm spring broken?
c.v.helleri
« Reply #2 on: January 03, 2012, 00:28:04 am »
  I'm not sure??  I do know that the release cone adaptor is twice as thick and the stage 1 pp that ate a t/o bearing clip.  I'm thinking this is what caused me to over extend the stage 2....
