September 22, 2026, 08:27:17 am
Need assistance with clutch set up....
Topic: Need assistance with clutch set up.... (Read 3614 times)
c.v.helleri
January 02, 2012, 19:36:34 pm »
I recently trashed a Kennedy stage 2 plate, and I may have over done the adjustment. When I removed the engine the disc wad just flopping around between the plate and flywheel. I made sure the clutch adjustment was correct per the Bentley manual. i'm at a loss as to what could have gone wrong.... Any insight will be appreciated so I don't make the same mistake twice....
Re: Need assistance with clutch set up....
January 02, 2012, 22:02:40 pm »
Is the main diaphragm spring broken?
c.v.helleri
January 03, 2012, 00:28:04 am »
I'm not sure?? I do know that the release cone adaptor is twice as thick and the stage 1 pp that ate a t/o bearing clip. I'm thinking this is what caused me to over extend the stage 2....
