October 15, 2026, 00:50:05 am
| | |-+  problems with the 8 spokes (again)
Author Topic: problems with the 8 spokes (again)  (Read 10585 times)
« on: May 27, 2007, 19:09:01 pm »
friday i finally got the rims back with tires on them. but 2 of them had the wrong size mounted so i only cold take 2...
anyway happy i returned home and was anxious to have them fitted under the car. i tried to put on the 2 back tires to check clearance. like i stated in an earlier post i have had some trouble fitting the riviera's with only 165 tires. so i jacked up the car and installed the EMPI's. well tried anyway. the problem was that i couldn't bolt them to the drums. as i found out the cups that go in the holes of the rim are to tall. the fit nice but they go to deep. resulting in a rim that is not fixed but bolts that are secured. so big NONO to me.
but what can i do now. i thought about machining the cups off, so they don't reach to far through the holes or do i need some sort of extra washer before i fit the cup?
i tried to take pictures, but alas the battery died the second i put the thing on. maybe later or tomorrow
pictures of your 8 spokes can help greatly
thanks
« Reply #1 on: May 27, 2007, 20:59:53 pm »
Hi nicolas are these Real Empi 8 Spokes were talking about?  If the Spacers are to long and go all the way threw the wheel and stick out on the back side you have BRM spacers there about .040 longer then 8 spoke spacers you can have them cut down the should be about .030 shorter then the thickness of the wheel here is a picture of Empi 8 Spoke Hardware
« Last Edit: May 27, 2007, 21:02:01 pm by Shubee2 (DSK) » Logged
« Reply #2 on: May 27, 2007, 22:26:28 pm »
yes indeed mine are taller. i guess i have BRM cups. who can help me to find the right stuff? i see those are some kind of studs and lugnuts. that is quite different from the cups and bolts i have at the moment.
thanks for the pictures.
Russell
« Reply #3 on: May 27, 2007, 22:36:09 pm »
Im currentyl getting 5 sets made for BRMs, however Im getting a set of cups for empi 5's made also which will use the same studs 14 /1.5 x 10 /1.5
hope this helps
Best Regards
Russell
« Reply #4 on: May 28, 2007, 03:36:00 am »
No big deal just grind a little off of the spacers.
« Reply #5 on: May 28, 2007, 09:59:39 am »
yes that would help a great deal. please mail me if you want to sell them to me.
thanks
ps please say what i need, because i wanted locks as well to have them safely on the car. but if i look at the pictures those locks look specific for this kind of wheel too.
« Reply #6 on: May 28, 2007, 16:45:58 pm »
nicolas if you want I want to passl to you my nuts and bolts of my empi 8 to have a reference
rgd
fabian
« Reply #7 on: May 29, 2007, 06:28:52 am »
yes that would help. i got my 8 spokes with cups and some kind of lugs. i saw a couple of pictures of the studs, but never realized they were specific items... so i hope that Russell can help me out or someone else who has some spare parts.
