September 24, 2026, 16:16:14 pm
| |-+  For sale!
| | |-+  WILWOOD Billet Spot Calipers and Type One Link Pin Brackets *PENDING*
Author Topic: WILWOOD Billet Spot Calipers and Type One Link Pin Brackets *PENDING*  (Read 5646 times)
Fasterbrit
« on: January 10, 2012, 22:40:24 pm »
Hi folks. Due to a caliper upgrade for proposed future road use, I am selling my Wilwood Billet Spot Caliper setup with AirKraft manufactured caliper mounts (T6 ali) to fit a Link Pin Bug standard spindle. This setup works pefectly with Wilwood hubs and most hubs with a 10" disc and works with zero offset wheels as well as pretty much any wheel you care to name. This is an incredibly light setup weighing just 850 grams a side including all hardware, pads and brackets. Ideally for a drag car setup. My car weighs 730kg (1600lbs) and had no problems stopping on the quarter mile from 145 + mph. I wouldn't really recommend them for road use, unless you run a very light car. They work awesome as a staging brake  Cool
They cost 106 US Dollars + shipping and tax each from the States and have had very little use. Lots of pad material left. The caliper mount brackets took me quite some time to make and are very sturdy, even though they are super light. Never had any problems with this setup!
Here's the blurb taken from Wilwood's website:
Wilwood’s 1.75” diameter single piston Billet Spot Caliper is ideal for Micro and Mini Sprint, Kart, Off Road, Motorcycle, Drag Race Spindle Mount and industrial applications. Designed for light duty use, this floating caliper weighs just 1.20 pounds and holds a round .25” thick, .7 cubic inch brake pad, and accommodates rotors from 6.00” to 13.00” diameter and widths starting at .12”. Maximum rotor width can be adjusted by specific bracket and spacer dimensions. The pads are held in place by stainless steel 10-24 x .38” long flat head cap screw (screws are included), and the caliper is available black anodized.
I am asking £120 + shipping and can be contacted on: 0781 4716578 UK... Matt
« Last Edit: January 24, 2012, 09:48:26 am by All Torque » Logged
www.air-kraft.com
www.marcomansiperformance.com
« Reply #1 on: January 11, 2012, 09:43:42 am »
Matt, does this mean the All Torque will have a tax disc in the near future?! Shocked
Fasterbrit
« Reply #2 on: January 11, 2012, 17:12:27 pm »
Maybe...  Wink
www.air-kraft.com
Fasterbrit
« Reply #3 on: January 23, 2012, 09:46:09 am »
New price: £120 bargainiferous !  Grin
www.air-kraft.com
