September 23, 2026, 22:28:27 pm
Fitting CSP AVIS adjusters
Topic: Fitting CSP AVIS adjusters (Read 6561 times)
RichardinNZ
January 12, 2012, 05:52:13 am »
I'll soon be pulling my beam apart for this. Somewhere I saw mention of heating and reshaping the dimples rather than drilling them out. Has anyone done this; is it just the back dimples that need reshaping?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Chris W
Re: Fitting CSP AVIS adjusters
January 12, 2012, 07:05:29 am »
I cut them all out and filled them. Also had to fill a bit of the front ones that the adjuster did not cover.
RichardinNZ
January 12, 2012, 09:16:26 am »
Hi Chris
Many thanks for the piicture; very neat! Will show it to the person welding my beam....
regards
Richard
Dual Carb 36hp
ibg
January 12, 2012, 10:53:16 am »
The other way is to heat the dimples nearly white hot and use a BFH and a pipe to push the centre piece along past the dimples, pushing the tube flat as it goes. Cut, weld and fill is much prettier.
RichardinNZ
January 14, 2012, 08:21:07 am »
Why is cut/fill prettier? Does the heating method look a bit of a mess afterwards; I have to get the final result certified (to meet our local laws) so it will need to look good!
Richard
Dual Carb 36hp
ibg
January 15, 2012, 00:21:25 am »
The dimples don't push out evenly, looks a bit like a crinkle cut potato chip in the dimple area. When the dimples are pressed into the beam the metal stretches, when you beat it out again it doesn't shrink.
RichardinNZ
January 16, 2012, 00:46:24 am »
Many thanks...will bear that in mind (will be tackling at Easter).
regards
Richard
Dual Carb 36hp
ibg
January 16, 2012, 11:22:48 am »
Richard, this is pretty funny, an Aussie giving advice to a Kiwi on a (mostly) Euro forum. It really is a world wide hobby
Ian, Melbourne Australia
RichardinNZ
January 18, 2012, 09:30:35 am »
Hi Ian
Yes...truly international, but we are almost neighbours!! Thanks for the help
Richard
Dual Carb 36hp
