October 14, 2026, 18:19:58 pm
| | |-+  Deep 6 Fuchs, short axles swing, 205 tyre, redrilled late drum
Author Topic: Deep 6 Fuchs, short axles swing, 205 tyre, redrilled late drum  (Read 7509 times)
pupjoint
« on: January 16, 2012, 02:41:07 am »
trying to make up an order from pelikan, planning to order the press in studs and spacers together, OEM or Porsche if possble.  I know the Fuchs need 30mm of protruding threads, hence think thickness of the spacers will determine the stud length i need to order.
i am currently running 205 70 R15 Michelin radials on 5.5" wide BRMs now, 66 Bug, original short axles, stock 66 drums, no touching or rubbing issues.
planning to swap with Deep 6 Fuchs, 15 x 6 no heart. any idea how thick spacers I would need to put?
i am more than happy to buy new smaller tyres if i can do away without any spacers.
currently away from home and car, so unable to do any trial fitting to confirm.
also, has anyone fitted 145 tyres to 6 inch wide rims before?
all the 4 pieces i got are the Deep 6, slowly locating for other sizes.
« Last Edit: January 16, 2012, 02:43:12 am by pupjoint » Logged
« Reply #1 on: January 16, 2012, 02:57:59 am »
You could just swap to type 3 drums to get the extra width...
pupjoint
« Reply #2 on: January 16, 2012, 03:01:31 am »
thanks, but not a viable option in my place, finding a pair of those Type 3 drums in good shape or even brake parts are even harder than locating another set of Fuchs.... Cry
Chris W
« Reply #3 on: January 16, 2012, 05:29:30 am »
I run a similar set up-
66 with short axles, 205/70's on Gas Burners (Fuchs 36mm offset 'burners are 42mm), late Type 3 hubs and drums and a 10mm spacer. I think I used a 42mm stud.
dirk zeyen
« Reply #4 on: January 16, 2012, 16:01:35 pm »
No 145 tyres but 155/65- 15 it works and looks good!!!
back again!!!
pupjoint
« Reply #5 on: January 16, 2012, 17:29:51 pm »
sigh...again cant find those sizes here.....you guys in the US are really lucky to have everything all over.
« Reply #6 on: January 16, 2012, 19:11:38 pm »
I have it on my 03. Looks good to me. Roll Eyes
http://cal-look.no/lounge/index.php/topic,10714.90.html
« Reply #7 on: January 17, 2012, 07:07:44 am »
Switch to long axle.
dirk zeyen
« Reply #8 on: January 17, 2012, 11:59:05 am »
I'm from germany Grin
http://www.ebay.de/itm/2-WINTERREIFEN-155-65R15-77T-M-S-AUDI-A2-REIFEN-UNIROYAL-NEU-/4002
Greetz: Dirk
back again!!!
donder
« Reply #9 on: January 17, 2012, 11:59:49 am »
I have same setup:
-59
-short axles,
-later drums redrilled to 5*130 and shortened the nose of the drum (10mm i think)
-25mm adapters (not just spacers, there are studs in the adapters so you don't need extra long studs)
-6" fuchs with a 195/70 goodyear gt2 tire and no rubbing issues after fitting the adapters ( fenders are perfectly filled)
- I also fitted 145r15 firestone f560 tires on the front ( tires are a bit stretched but i works, still, i'm in doubt to have them narrowed)
http://www.wunderwaffe.be/blog/   --> OCT-411
