October 14, 2026, 19:26:11 pm
Deep 6 Fuchs, short axles swing, 205 tyre, redrilled late drum
Topic: Deep 6 Fuchs, short axles swing, 205 tyre, redrilled late drum (Read 7510 times)
pupjoint
January 16, 2012, 02:41:07 am »
trying to make up an order from pelikan, planning to order the press in studs and spacers together, OEM or Porsche if possble. I know the Fuchs need 30mm of protruding threads, hence think thickness of the spacers will determine the stud length i need to order.
i am currently running 205 70 R15 Michelin radials on 5.5" wide BRMs now, 66 Bug, original short axles, stock 66 drums, no touching or rubbing issues.
planning to swap with Deep 6 Fuchs, 15 x 6 no heart. any idea how thick spacers I would need to put?
i am more than happy to buy new smaller tyres if i can do away without any spacers.
currently away from home and car, so unable to do any trial fitting to confirm.
also, has anyone fitted 145 tyres to 6 inch wide rims before?
all the 4 pieces i got are the Deep 6, slowly locating for other sizes.
Last Edit: January 16, 2012, 02:43:12 am by pupjoint
Re: Deep 6 Fuchs, short axles swing, 205 tyre, redrilled late drum
January 16, 2012, 02:57:59 am »
You could just swap to type 3 drums to get the extra width...
pupjoint
January 16, 2012, 03:01:31 am »
Quote from: Zach Gomulka on January 16, 2012, 02:57:59 am
thanks, but not a viable option in my place, finding a pair of those Type 3 drums in good shape or even brake parts are even harder than locating another set of Fuchs....
Chris W
January 16, 2012, 05:29:30 am »
I run a similar set up-
66 with short axles, 205/70's on Gas Burners (Fuchs 36mm offset 'burners are 42mm), late Type 3 hubs and drums and a 10mm spacer. I think I used a 42mm stud.
dirk zeyen
January 16, 2012, 16:01:35 pm »
No 145 tyres but 155/65- 15 it works and looks good!!!
back again!!!
pupjoint
January 16, 2012, 17:29:51 pm »
Quote from: dirk zeyen on January 16, 2012, 16:01:35 pm
sigh...again cant find those sizes here.....you guys in the US are really lucky to have everything all over.
January 16, 2012, 19:11:38 pm »
Quote from: pupjoint on January 16, 2012, 02:41:07 am
I have it on my 03. Looks good to me.
http://cal-look.no/lounge/index.php/topic,10714.90.html
January 17, 2012, 07:07:44 am »
Switch to long axle.
dirk zeyen
January 17, 2012, 11:59:05 am »
I'm from germany
http://www.ebay.de/itm/2-WINTERREIFEN-155-65R15-77T-M-S-AUDI-A2-REIFEN-UNIROYAL-NEU-/4002
Greetz: Dirk
back again!!!
donder
January 17, 2012, 11:59:49 am »
I have same setup:
-59
-short axles,
-later drums redrilled to 5*130 and shortened the nose of the drum (10mm i think)
-25mm adapters (not just spacers, there are studs in the adapters so you don't need extra long studs)
-6" fuchs with a 195/70 goodyear gt2 tire and no rubbing issues after fitting the adapters ( fenders are perfectly filled)
- I also fitted 145r15 firestone f560 tires on the front ( tires are a bit stretched but i works, still, i'm in doubt to have them narrowed)
http://www.wunderwaffe.be/blog/
--> OCT-411
