November 04, 2026, 10:11:15 am
| | |-+  Machining heads for higher compression
Author Topic: Machining heads for higher compression  (Read 4706 times)
« on: January 22, 2012, 22:50:55 pm »
Hi guys,
My heads have a cc of 52, I would like to flycut them for lower cc and hence higher the compression ratio (think I got that the right way!)
How do I know how deep to cut for each cc?
Lee
Jesse/DVK
'64 2176cc
« Reply #1 on: January 22, 2012, 23:22:37 pm »
Determine the CC's you would like to have an fill the head with that amount of water and you know how far to go.
« Reply #2 on: January 22, 2012, 23:29:12 pm »
Thank you, knew it would be a simple answer Grin
Lee
« Reply #3 on: January 23, 2012, 00:27:47 am »
Depending on the shape of the combustion chamber, it IS possible to calculate the amount of cut needed beforehand ...
I've done it many times.
The problem with water is working around and estimating for the deviance in measurement considering the meniscus.
TxT
« Last Edit: January 23, 2012, 00:33:01 am by TexasTom » Logged
