September 23, 2026, 13:37:50 pm
Valve springs preventive change?
Topic: Valve springs preventive change? (Read 5396 times)
181
January 27, 2012, 15:48:03 pm »
Is it wise to change the valve springs from preventive reasons? I´m going to pull my 2276 engine after two seasons (around 10 000 km and around 40 1/4 passes). Heads are basicly Steve Tims Stage 2 with dual valve springs, stainless steel valves. Cam is FK8 going to be changed for 86C, engine pulls to 6500RPM.
With engine out, should I change the springs for a new set?
Thanks,
Jan
Last Edit: January 27, 2012, 15:59:03 pm by 181
Erlend / bug66
Global Moderator
SCC Event
Re: Vlave springs preventive change?
January 27, 2012, 15:54:43 pm »
I'm going to run 86C with a set of VW650 springs.
Springs need to be matched to lift of cam + rockers
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
181
Re: Valve springs preventive change?
January 27, 2012, 16:00:17 pm »
Rockers will be the same - CB´s 1.4:1. FK8 and 86C have a very close, if not the same valve lift.
JS
January 27, 2012, 16:27:54 pm »
I would take them off and go to a machine shop to have them tested.
Signature.
January 28, 2012, 13:21:34 pm »
it can work, but in my opinion when the springs are 'set' for a cam, i would change them when you put in a new cam, i think they could break when subjected to higher lifts, faster ramps,...
