November 02, 2026, 14:09:51 pm
| | |-+  Valve springs preventive change?
Author Topic: Valve springs preventive change?  (Read 5518 times)
181
« on: January 27, 2012, 15:48:03 pm »
Is it wise to change the valve springs from preventive reasons? I´m going to pull my 2276 engine after two seasons (around 10 000 km and around 40 1/4 passes). Heads are basicly Steve Tims Stage 2 with dual valve springs, stainless steel valves. Cam is FK8 going to be changed for 86C, engine pulls to 6500RPM.
With engine out, should I change the springs for a new set?
Jan
« Last Edit: January 27, 2012, 15:59:03 pm by 181 » Logged
« Reply #1 on: January 27, 2012, 15:54:43 pm »
I'm going to run 86C with a set of VW650 springs.
Springs need to be matched to lift of cam + rockers
181
« Reply #2 on: January 27, 2012, 16:00:17 pm »
Rockers will be the same - CB´s 1.4:1. FK8 and 86C have a very close, if not the same valve lift.
« Reply #3 on: January 27, 2012, 16:27:54 pm »
I would take them off and go to a machine shop to have them tested.
« Reply #4 on: January 28, 2012, 13:21:34 pm »
it can work, but in my opinion when the springs are 'set' for a cam, i would change them when you put in a new cam, i think they could break when subjected to higher lifts, faster ramps,...
