September 22, 2026, 21:25:21 pm
| | |-+  Gland nuts
Author Topic: Gland nuts  (Read 9924 times)
« on: January 27, 2012, 21:29:29 pm »
What would you use and why?
Had a 42mm lying around but it was suggested that a 36 would be better.
glenn
« Reply #1 on: January 27, 2012, 23:10:52 pm »
Berg 36mm forged.
Plenty strong and you can use a torque multiplier to torque it to spec.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #2 on: January 27, 2012, 23:28:17 pm »
I normally run the Berg unit, but have also used the Scat glandnut ... torqued to 500lbft no problem Wink
TxT
neil68
« Reply #3 on: January 28, 2012, 00:21:31 am »
Bugpack chromoly 36 mm gland nut torqued to 405 ft lb...
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
stealth67vw
« Reply #4 on: January 28, 2012, 04:42:54 am »
Same here, also torqued to 405lbs.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #5 on: January 28, 2012, 05:14:52 am »
I use the stock one.  Torque it to 400.
« Reply #6 on: January 28, 2012, 05:47:02 am »
Berg when they used to be available,but since Scat came out with a 36mm version i have used that alot,even torqued it to 650lbs on a wedgemated engine,seems just a good as the berg but 1/2 the cost
« Reply #7 on: January 28, 2012, 09:07:34 am »
Thanks guys.  36mm forged it is.
Dominick Luppino
« Reply #8 on: January 30, 2012, 16:22:48 pm »
The BUGPACK 4035-11 Chromoly Gland nut works great for me, made in the USA!
Black Sheep
less is more
« Reply #9 on: January 30, 2012, 21:43:01 pm »
Does anyone stock the scat 36mm this side of the pond ?  coz I could use one too , I minced the old 42 taking it off for my rebuild .
last time I looked it was a stateside order  Undecided
13.03 @ 98mph
« Reply #10 on: January 30, 2012, 22:16:03 pm »
I tested the Scat gland nut just to see what will give up first. Measured the length then torqed to 1000nm - 740lbs. Measured it again, no stretch or any sign of damages. The German crank was also ok. Torqed it again to 1500nm - 1100lbs and again no damages. I gave up but next time I will continue to torque until something give up. It is amazingly easy when you use the torque meister.
-BB-
« Reply #11 on: January 30, 2012, 22:51:41 pm »
JC has used a forged 36mm on my crank, so try him or you can have the 42mm.
jaqo
Bugster Team
« Reply #12 on: January 31, 2012, 00:53:55 am »
I probably have few of them. Can check if you want.
Jo Clifford
« Reply #13 on: January 31, 2012, 01:18:50 am »
Hi Glen
Got them in stock in UK, can get one to you by end of the week.
Jo
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Black Sheep
less is more
« Reply #14 on: January 31, 2012, 07:13:34 am »
cheers jo
13.03 @ 98mph
Black Sheep
less is more
« Reply #15 on: February 09, 2012, 11:21:48 am »
Came this morning  Cool Cheers Jo Jo
13.03 @ 98mph
