September 22, 2026, 06:14:33 am
| | |-+  No oil getting past push rods
Author Topic: No oil getting past push rods  (Read 15572 times)
Chuck Fryer
« on: February 06, 2012, 17:19:55 pm »
I bought an engine with low miles (800) a while back. I am just now getting it started after a cam, compression and rocker arm change. I have ran the engine on my test stand for a few minutes and when I went to adjust the valves I noticed that there was NO oil in the heads. The pushrods are full but the oil has not gone past the adjuster screw. Is it that the oil just didn't get warm enough and thin out? Shell rotella 15w40. I an using what appears to be a run of the mill set of 1.4 rockers. Any ideas what I should look at?
84x94
fk87
wedgeports
« Reply #1 on: February 06, 2012, 17:50:18 pm »
I bought a set of Bugpack HD aluminium pushrods that weren't drilled all the way through on HALF of the tips!
Something to check...
Chuck Fryer
« Reply #2 on: February 06, 2012, 19:18:37 pm »
Pushrods are all clean, I made sure to check everyone when it went together.
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: February 06, 2012, 19:22:30 pm »
I've seen scat lube a lobe and CB lifters with partially blocked oil holes,,
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Fritter
« Reply #4 on: February 06, 2012, 20:02:10 pm »
Chuck, how did the rockers check out?
Mike F.
'64 Indigo Blue sunroof Bug
Cheesepanzer
« Reply #5 on: February 06, 2012, 20:46:16 pm »
Rockers or the adjuster screws would be what I'd double check.  Weird...
63 Type 2 Single Cab
Cornpanzers
« Reply #6 on: February 06, 2012, 21:21:14 pm »
Make sure the oil holes in the rocker adjusting screws go all the way through.
Chuck Fryer
« Reply #7 on: February 06, 2012, 22:43:57 pm »
I tool the rockers apart and can blow air thru the adjuster and it comes out the little hole in the rocker shaft area. Then I put  the rocker back on the shaft.  When I put it up to my mouth and blow ( hey no funny comments!) I cannot get air to pass thru. I know you cannot build up much if any psi this was but thought I would try it. I guess I will give a try to loose adjustment, but I know the oil is getting to the pushrods, they are full.
Fritter
« Reply #8 on: February 06, 2012, 23:17:06 pm »
Rocker bores too tight on rocker shaft?  Odd....
Mike F.
deano
« Reply #9 on: February 06, 2012, 23:44:35 pm »
Now doesn't the pushrods get their oil from the lifters? And are you sure the lifters are getting oil? I think you need to check up-stream with your problem.
Anglia Obsolete Guru
'67 Heaven
« Reply #10 on: February 07, 2012, 00:02:54 am »
I'd try using an oil squirt can on each adjuster screw oil hole (leave the rocker arm assemblies together) to pump some oil into the shafts.
Chuck Fryer
« Reply #11 on: February 07, 2012, 00:03:17 am »
But the pushrods are full of oil. Maybe I am ignoring upstream since they have oil.
« Reply #12 on: February 07, 2012, 00:06:46 am »
The adjusters should have an oil groove part way up the threads... maybe the screws are adjusted too far out or too far in to match the oil port on the rocker.
« Reply #13 on: February 07, 2012, 00:09:45 am »
I was just thinking the same thing.
deano
« Reply #14 on: February 07, 2012, 02:07:18 am »
I recall when using Scat 1.4:1 rockers, there was a sweet spot for the position of the adjusting screw. You had to basically line up the oil slot in the screw, to the rocker arm hole, and then lock-down the jam nut and adjust everything else to suit (pushrod length, etc). So, I believe Sarge has got it right.l
'67 Heaven
Chuck Fryer
« Reply #15 on: February 07, 2012, 03:33:15 am »
Gives me a few things to check out this week, thanks.
« Reply #16 on: February 07, 2012, 09:40:36 am »
3 turns out Smiley
cheers richie
Dominick Luppino
« Reply #17 on: February 07, 2012, 16:08:46 pm »
3 turns out Smiley
cheers richie
X2
« Reply #18 on: February 07, 2012, 20:20:15 pm »
3 turns out Smiley
cheers richie
X2
yep that is the sweetspot.
Chuck Fryer
« Reply #19 on: February 08, 2012, 00:49:55 am »
It appears that the problem is gone. Today I adjusted the valves WAY loose ( thanks Richie ) and ran the engine with no covers. After about 20 seconds there was oil coming out between the pushrods and the adjuster cup. Next I adjusted the valves back to 0 lash and ran it again. Oil did start to splash around and seems to be going where it was supposed to. Then I took off a rocker just to see if oil was making its way up to the shaft, and it was.
Last time the head was DRY, nothing on the inside of the valve cover and nothing under the pushrods after 3-4 minutes of running. This time I basically took it apart and put it back together. I'm probably going to replace the adjusters and let the rest go. Still not sure what changed, but hey, its working.
Fritter
« Reply #20 on: February 08, 2012, 00:53:40 am »
Good to hear!
Mike F.
« Reply #21 on: February 08, 2012, 01:37:17 am »
Just make sure you are getting oil at all eight rockers and not just a few.
Chuck Fryer
« Reply #22 on: February 09, 2012, 00:13:44 am »
Pictures for reference
Fritter
« Reply #23 on: February 09, 2012, 00:53:37 am »
Yep, that groove in the threaded adjuster appears to be a critical piece of the puzzle!
Mike F.
« Reply #24 on: February 09, 2012, 01:28:33 am »
I'd also check why the furthest rocker in the photo is adjusted so much different than the others.
