October 13, 2026, 23:18:07 pm
'58 Sedan Race Car for Sale
Topic: '58 Sedan Race Car for Sale (Read 3953 times)
old balls
February 08, 2012, 03:13:09 am »
1958 sedan no motor [ Attachment: You are not allowed to view attachments ]
Steel body fiberglass rear fenders ,rear apron,deck lid and front hood
Fresh Rancho pro comp transmission gusseted case all new bearings and seals 091 idler ,close ratio gears aluminum spool, dual steel side covers, good set sway away axles solid mounted raised 2"
type3 rear brakes exrernally adjustable shocks and custom limiting straps
holly red pump and stainless lines, spun aluminum fuel tank with custom sump,solid aluminum return line
optima battery ,line lock, monster tach external on/off switch remote starter switch in engine bay
8 point cage tied into pan ,rear torsion and frame hornes,5 point harness and window net has dash bar diagonal header bar and door bars
cage is fully tig welded
center line wheels 26x8 1/2 slicks
car went 10.30@131
$ 3,500
includes set of early fiberglass doors aluminum door panels
and new lexan windows
Scott 1-714-345-7006
Last Edit: March 08, 2012, 02:59:38 am by old balls
Re: '58 Sedan Race Car for Sale
February 08, 2012, 03:55:42 am »
Scott... how the heck are you?
