September 22, 2026, 23:56:05 pm
| | |-+  Rear A Arms
Author Topic: Rear A Arms  (Read 10147 times)
Andy Sykes
« on: February 11, 2012, 21:04:29 pm »
Hi I'm using a G50 gearbox so IRS I'm goin to make some rear a arms so I don't get any neg camber has anybody got any pictures for ideas I have a few but more would help
Cheers andy
Mike Lawless
« Reply #1 on: February 11, 2012, 22:05:22 pm »
http://home.comcast.net/~mlawless29/wkrswingtoirs.html
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
Andy Sykes
« Reply #2 on: February 11, 2012, 22:09:23 pm »
That's cool thanks do you get any camber change?
Cheers andy
Mike Lawless
« Reply #3 on: February 11, 2012, 22:51:11 pm »
Yes but not very much. about 4° over the entire travel. This is due to the pivot points not being on a straight plane to the axle. For a drag car, it's not too bad. It's WAY better than the folts swing axle set-up it replaced. This is because the pivot points are a lot farther outside than the stock swing axles are. The toe change was severe too. Now it's not!
At ride height, there's about 1/2° positive camber. I built them with about 1 to 1.5° positive camber at ride height to factor in some flex.
Andy Sykes
« Reply #4 on: February 11, 2012, 23:04:16 pm »
That's great info thanks Smiley
Cheers andy
Fasterbrit
« Reply #5 on: February 12, 2012, 09:59:06 am »
Check out Adelle and Steve's car in the 'in da werks' section as they had some fantastic a-arms made by Wayne Allman at the Intergallictic Custom Shop. Great design with zero camber change. The only thing I would change on the design is to make a provision for adjusting the camber for initial setup. I am sure Wayne would make you a set. His work is some of the best around  Wink
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #6 on: February 12, 2012, 10:57:14 am »
Cheers they look nice they are just what I was thinking of I've made the bosses
tapped out to m22x1.5mm
I'm using these bearing housings
cheers andy
Andy Sykes
« Reply #7 on: March 04, 2012, 19:09:37 pm »
So they ended up like this I'm no regular welder but turned out ok
all i have to do if fab up a bracket for the coil overs
for a bit of extra strength i plug weled the bosses in as well
cheers andy
« Reply #8 on: March 05, 2012, 04:26:56 am »
Hi, can you describe better how to find the car in da werls or just link it?
I have also written to Wayne Allman.
Fredrik
Fasterbrit
« Reply #9 on: March 05, 2012, 09:08:22 am »
Hi Frallan. It's in da werks section entitled: 'my new car for next year'. It's by Adelle Vw
Bit of an update..
A arm in the making, the bearing housing is cut from a stock VW IRS arm so bearings are easily available and I can use my existing RLR/Strange brakes.
3/4 built arms
Locating mounts tacked into position for mock up
Not sure on final ride height yet..
« Last Edit: March 05, 2012, 09:11:05 am by All Torque » Logged
www.air-kraft.com
« Reply #10 on: March 05, 2012, 11:19:25 am »
Thanks All Torque.
SteveW
« Reply #11 on: March 05, 2012, 21:16:46 pm »
Frallen, I have more pics of the A Arms on my blog here..
http://vintageairuk.wordpress.com
If you need any info or Wayne's contact details let me know Smiley
Steve
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
« Reply #12 on: March 06, 2012, 03:51:16 am »
Nice!
Inspiring. Like your car in general Well done.
Andy Sykes
« Reply #13 on: March 17, 2012, 17:22:54 pm »
Here's mine fitted up just need to finish a few weld off
Cheers Andy
