September 23, 2026, 02:29:05 am
| | |-+  48 IDA fuel inlets sizes
Author Topic: 48 IDA fuel inlets sizes  (Read 6180 times)
chez2165
« on: February 17, 2012, 01:17:48 am »
I have a pair of IDA's with the fuel fitting currently fitted to the side of the carb but was considering swapping the fitting to the top of the carb for extra fan housing clearance and was wondering if the threads are the same size or not.
« Reply #1 on: February 17, 2012, 06:35:16 am »
They are not the same. JC Ent. sells the fittings for what you want, a plug for the side and a AN type fitting for the top. Used them in plenty of motors, works great, and not expensive.
Ted
Jeff68
« Reply #2 on: February 17, 2012, 15:27:29 pm »
I used the JC top IDA inlets on my car too.  My engine is on the narrow side (82 with Porsche length rods).  I used a thing fan shroud and the side inlets were to close to the shroud.  The top inlets work fine.
2manytoys
« Reply #3 on: February 17, 2012, 17:47:43 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=253238
« Reply #4 on: February 18, 2012, 14:22:59 pm »
We do have 1 set for sale here in uk if you needed them
Hotrodvw
« Reply #5 on: February 26, 2012, 01:31:47 am »
I just installed fittings in my IDA's but my memory sux  Cheesy
I believe the tops are 14mmx1.5, and the stock side inlets are 12mmx1.5.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
