August 24, 2026, 19:53:54 pm
Any suggestion on best manifolds for dell 40s on 1776?
Topic: Any suggestion on best manifolds for dell 40s on 1776? (Read 15193 times)
stait9
February 20, 2012, 23:19:42 pm »
Have discovered that manifolds currently on the car are for 48 IDAs, not 40 Dells (will be selling them shortly if anyone interested)
So need new ones but would still to run with deck lid shut and air cleaners.
Any suggestions?
Stuart
glenn
Re: Any suggestion on best manifolds for dell 40s on 1776?
February 20, 2012, 23:24:43 pm »
CB offset manifolds work well.
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
stait9
February 20, 2012, 23:34:09 pm »
Thanks Glenn, will have a look at those
j-dub
February 21, 2012, 02:49:13 am »
I run the CB ones as well, they are affordable, have plenty of meat for match porting and are easily available.
February 22, 2012, 02:15:49 am »
The current EMPI/Mr. Bug manifolds are junk, stay away from them. They are weak and prone to breaking at the bottom flange. Also, when DRLA Dellortos are bolted to them, they will interfere with a stock DH fan shroud. They were designed for Weber IDFs.
The CB manifolds are good quality. They won't break like the EMPI ones. They fit well. But they have a problem. The hole at the top is 50mm in diameter. This is OK for a 48 mm carb, but it's bad for a 40mm carb. The CB manifolds used to be made with a 40mm hole at the top, but it's been about 20-25 years since they made them. They do show up at swap meets occasionally.
CSP sells a manifold that is 40mm at the top. This is the one to get.
Brandon Sinclair
February 22, 2012, 03:54:00 am »
Here are the CSP that Bruce is talking about where the manifold hole is not oversized and fits the 40mm carb...
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31%2D129%2D711%2D140
February 22, 2012, 07:17:22 am »
Sorry but these are the best . They do not need much port work because they have some bigger diameters inside and are offered with big or original flansh . They come in 48 and 40 mm also the 40's can get ported to 44 very easy , inside goes from 40- 42 and then smaller
www.Udobeckertuning.de
February 22, 2012, 08:53:12 am »
They look heavy. And they are not offset, so will CB linkage work???
Where are they available from? $£€?
viNce
February 22, 2012, 09:43:45 am »
I also like bugpack #1038 manifolds.
CB sells base plates to fit their linkage on straight manifolds.
http://cbperformance.com/catalog.asp?ProductID=509
February 22, 2012, 15:28:02 pm »
CSP 40mm specific manifolds
February 22, 2012, 19:05:51 pm »
Berg GB580As ... 40mm throat to work with those carbs.
TxT
stait9
February 22, 2012, 20:50:02 pm »
Thanks everyone, great feedback.
Interestingly Bruces point about the wrong size diameter top is exactly the problem discovered. It was giving a flat spot it seemed. Thanks Bruce for the info.
Udo - they look interesting, which make are they?
February 22, 2012, 20:50:45 pm »
Quote from: Bruce on February 22, 2012, 08:53:12 am
They are avaliable at my shop or csp, price is 180 euros. They work with csp linkage , i use the german riechert on most engines. Looks like old school then
February 23, 2012, 06:31:26 am »
Quote from: viNce on February 22, 2012, 09:43:45 am
Here's the description from the Bugpack site:
"1038 Dual Tall 40-44IDF/DRLA Manifolds"
This tells me the hole at the top is at least 44mm in dia. It's not too bad, but a 40mm hole is ideal.
PH1303
February 24, 2012, 12:24:21 pm »
One thing to consider when using CB's off set manifolds is that the flow isn't quite as good as with more straight intake runners. When we visited Johannes Perssons Dynoday a couple of years back, he flow tested CB off set manifold among others. At the given flow test, they flowed 10 - 13 hp less than other symmetric intake manifolds. So, they will fit well in the engine compartment, but will not get the optimal out off your carbs.
/Peter
February 24, 2012, 18:04:13 pm »
I started producing my manilfolds because all others are too small inside and outside and most have different length . The only ones are the Bergs that work fine . But they do not fit with orginal fan housing and are too short
didi
February 24, 2012, 22:12:38 pm »
Udo's manifolds are great quality products. And they will also fit with narrowed engines and original fan shroud.
Didi - Aircooled VW
http://didivw.blogspot.com/
February 25, 2012, 01:59:23 am »
Nice, like to try a set of those ...
qubek
February 28, 2012, 13:49:19 pm »
Quote from: Udo on February 22, 2012, 20:50:45 pm
So are CSP DRLA/IDF 40 manifolds (part number 129 711 140) the ones you are talking about, or a different product?
February 29, 2012, 08:37:59 am »
Quote from: PH1303 on February 24, 2012, 12:24:21 pm
Can you find out more info on this testing? What kind of engine was used? What size carbs? Which CB manifolds were used, the ones that are 50mm at the top, or properly sized ones?
Also, your statement is confusing. Flow isn't measured in hp. Was it a flowbench comparison test, or was it on a dyno?
PH1303
March 02, 2012, 23:12:24 pm »
It was a flow test - as I wrote earlier. I should have written ... which could be compared to 10 - 13 hp. As you properbly know, it is generally accepted that flow tests performed with a depression of 25 mm hg, and measured in cfm, can be compared to what can be achieved as engine hp output (if all components are mixed correct)
Can't remember if CB's offset manifolds are 48 or 50 mm in the top?
However, there was a small Dyno Day "report" online some time after the meeting. But I can't seem to find it now...
It is several years back. Maybe some other scandinavian callook lounger members can find it somewhere?
/Peter
Last Edit: March 02, 2012, 23:22:00 pm by PH1303
Svwerker
March 03, 2012, 07:13:39 am »
You can find the test under Dynoday 2004 on JPM's site, only in swedish.
The test was made with a 044 head with 40*35,5 valves, unported.
Lift (mm) Offset Straight
2 40,1 41,1
4 69,2 71,4
6 90,2 93,6
8 103,5 110,6
10 111,7 122,6
12 116,5 128,1
14 118,9 132,3
16 121,7 135,2
March 03, 2012, 18:02:05 pm »
different length of ports in one manifold can not be good...
