October 18, 2026, 17:30:28 pm
another set of limbach aircraft heads, waterboxer studpattern
Topic: another set of limbach aircraft heads, waterboxer studpattern (Read 8457 times)
karl h
February 22, 2012, 13:45:24 pm »
used on an aircraft motor, have to be replaced every couple of thousand hrs.
perfect for converting a waterboxer engine to air
pair 400€
ANOTHER SET
SEE BELOW
Last Edit: June 18, 2012, 07:18:54 am by karl h
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Re: set of limbach aircraft heads, waterboxer studpattern
February 22, 2012, 15:23:14 pm »
I presume they are twin-plugged, too. Cool!
karl h
February 22, 2012, 16:26:26 pm »
the casting is actually usable in a twin plug configuration, but are not machined for a second plug
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
PH1303
February 23, 2012, 13:20:40 pm »
Hi
What size valve are they equipped with? And are there any defects such as cracks between the valve seats or broken cooling fins?
Best regards,
karl h
February 23, 2012, 19:23:19 pm »
no cracks, no broken fins, stock size valves (35x32)
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
PH1303
February 23, 2012, 22:47:44 pm »
Ok - sounds good.
Are the valve guides worn? Proberly not really an issue, since the valve seats most likely will be replaced for some bigger seats...
Could you please opload some pictures of the combustion chamber side?
/Peter
still-water
February 23, 2012, 22:55:50 pm »
Quote from: karl h on February 23, 2012, 19:23:19 pm
Hi Karl,
please check your PM's .
Regards S.
karl h
February 24, 2012, 09:10:10 am »
i will post some more pics on sunday
valveguides are ok
i havent gotten a PM
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
PH1303
February 24, 2012, 12:13:50 pm »
I am interested in the heads.
I live in Copenhagen, so please consider how to ship them, and let me know the cost.
I reserve the right to back out of this deal, if the pictures of the chambers not are what I expect.
Best regards,
Peter Hagen
bedjo78
February 25, 2012, 06:04:29 am »
Interested.
please post pic's
karl h
February 26, 2012, 17:27:18 pm »
heads pending to steve
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
PH1303
February 26, 2012, 21:51:43 pm »
Ok. If the deal for some reason fails, I would like to buy the heads. Or if you get your hands on another set of heads, I would be interested.
/Peter Hagen
karl h
February 27, 2012, 13:59:10 pm »
heads are sold
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
June 14, 2012, 12:37:26 pm »
i have another set for sale
400€
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
karl h
Re: another set of limbach aircraft heads, waterboxer studpattern
June 18, 2012, 07:19:52 am »
bump
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
