November 02, 2026, 23:28:55 pm
1930 Ford track T roadster
Topic: 1930 Ford track T roadster (Read 72698 times)
Frenchy Dehoux
Re: 1930 Ford track T roadster
Reply #60 on:
December 12, 2013, 16:55:51 pm »
A bit more progress this past week did the fuel lines and finish the rear brake line to the frame with a flexible rubber line. All of the fuel lines will have a compressed ring to join the rubber hose. All of the brake and fuel lines will be painted gloss black and the brakets will be polished. I also started to work on the firewall. The brass fitting also will be polished.
Frenchy
Doctor Detail ( Retired )
Reply #61 on:
December 13, 2013, 07:29:13 am »
I would STRONGLY recommend you not use that plastic Facet fuel pump.
Frenchy Dehoux
Reply #62 on:
December 13, 2013, 19:16:22 pm »
Have you had issues with them let me know.
Frenchy
Reply #63 on:
December 16, 2013, 17:45:40 pm »
When I worked for NAPA I used to warranty them all the time. They would leak everywhere. Is your car better then a plastic fuel pump?
Frenchy Dehoux
Reply #64 on:
December 29, 2013, 19:10:35 pm »
Made some progress on the 31 project yesterday. We made our firewall from various other firewall to fit because originally the body was narrowed 6 inches so the Duval windshield would look appropriate to the body lines. Next I will make the rest of the firewall once I have the template made. Inside the body I had to cut part of the floor board for the driveshaft hoop to fit.
Frenchy
Frenchy Dehoux
Reply #65 on:
December 29, 2013, 19:12:05 pm »
One more the driveshaft hoop.
Frenchy
Frenchy Dehoux
Reply #66 on:
January 02, 2014, 17:11:47 pm »
I did accomplish a lot these past few days the firewall was the main area I wanted to get done and was able to fit the steering column as well. I have my parts from Speedway arriving this afternoon and wanted the firewall completed.
Frenchy
Frenchy Dehoux
Reply #67 on:
January 28, 2014, 17:00:13 pm »
A few updates the firewall is done also installed the Beehive oil filter I will have to modify the bracket so the filter is level because of the firewall is at an angle. Also made the wood floor for the inside of the car with 3/4 plywood that will be painted black with a rubber mat sitting on top. The seats I bought at Bass Pro shop and they will be redone in black with gold stiching with the V8 logo in the center also in gold. The body will be done in flat black with the Duval windshield polish brass the engine will be painted in gold close match to the windshield frame. The headlight buckets are going and be gloss black and the headlight rings in brass the fuel tank is the oval style and will be painted gloss black with the brass straps. Dash panel gloss black with the gold style gauges. I will be posting more pictures as I move along.
Frenchy
Frenchy Dehoux
Reply #68 on:
January 28, 2014, 17:01:51 pm »
Here a few more.
Frenchy
