August 12, 2026, 18:23:29 pm
| | |-+  car weight
Pages: 1 [2] Print
Author Topic: car weight  (Read 28063 times)
dannyboy
« Reply #30 on: March 03, 2012, 00:04:00 am »
 599 kgs  Shocked  bloody hell thats a serious diet to put a car on  Cheesy
8.77@156.8mph
O/FF 60
Phil West
« Reply #31 on: March 03, 2012, 08:58:31 am »
I remember the first weigh-in I ever did it was 740kg.  Which means it took me over 10 years work to lose the 141kgs -with the power I had 600kg was the ultimate target.  Funnily enough as soon as I went lower the car ran into the 10's.  Admittedly a few other mods helped too!
Turbo_Rich
« Reply #32 on: March 03, 2012, 12:20:02 pm »
Rich I bet those wheels and tyres together with the 915 add about 150lbs to a normal bug,is it a steel or moly cage,its funny that the cars with the type 4[you & Patte] in are the heavyweights,must be something there Cheesy
Yep the repro gas burners are pretty damn heavy- working on getting the original Fuchs back on to save weight. The cage is all steel and mig welded so the welds must be adding up LOL
Nothing wrong with the type 4 i think its all the oil in it thats the problem  Grin
Phil- that weight is insane. Good work! Do you have to peg it down in a light breeze?  Cheesy
Jyrki
8.88 & 251
« Reply #33 on: March 04, 2012, 09:05:44 am »
730kg turbo car Wink
With you in it?  i wish mine was that light,they are 878kg and 879kg with me in them
930kg here with the '65 street car, with driver. The car has been on a 100kg diet, but due to the heavy transmission, turbo engine, liquid-intercooler, roll-cage ets, it weights 100kg more than a standard '65. Mid-9s with appr. 435whp.
The new racecar oops, street car will propably weight at least the same as Richie's. It has a very heavy transmission, turbo engine and liquid-IC (gallons of water  Embarrassed), twin batteries, ballast weights, 100% steel body...
Jyrki
« Last Edit: March 04, 2012, 09:34:50 am by Jyrki » Logged
Andy Sykes
« Reply #34 on: March 04, 2012, 13:51:16 pm »
I dread to think what mine will weight in at  Grin
Cheers andy
Phil West
« Reply #35 on: March 04, 2012, 16:07:13 pm »
No pegging down but it sure is easier pushing it around the workshop, loading on and off the trailer, moving around the pits, plus less weight to tow to the track so it all helps!  Still nice and steady at 125mph although I'm not sure if it would like going too much faster as is.........
james wotton
« Reply #36 on: March 04, 2012, 20:12:04 pm »
my old banger weight's in at 850k inc me.
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
Bernard Newbury
9.50 @ 141 MPH
« Reply #37 on: March 04, 2012, 21:41:55 pm »
780 kg including me. I've put on weight since I stopped smoking !!
Fasterbrit
« Reply #38 on: March 04, 2012, 23:08:08 pm »
stopping smoking may have helped you break the 'nines' Bernie. One hand on the wheel and the other smoking a fag doesn't make for good pb's  Grin
www.air-kraft.com
www.marcomansiperformance.com
m.m.p
« Reply #39 on: March 04, 2012, 23:38:59 pm »
My grey bug was 2270lb with me in it, ran 10.80 1/4 and was 1770lb without me! hahahah ;0 my balls were heavy back then!
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Crazy Mc.Stairs
« Reply #40 on: March 05, 2012, 20:46:32 pm »
My black turbo bug 840kg, with me in it 920kg Wink
Christoph
hector
« Reply #41 on: March 31, 2012, 09:11:50 am »
mines 698kg in street trim and about 4 tonne with me in it ! Cheesy
outlawflatfour.com farmers division
Tekken
www.proturbovw.com
« Reply #42 on: March 31, 2012, 09:44:09 am »
875kg with driver and lots of led,water tank,twin batteries etc..
grillos racing
« Reply #43 on: March 31, 2012, 09:56:21 am »
Tar Babe 515 kilos
Chris bugster
« Reply #44 on: June 15, 2012, 21:05:31 pm »
All weights without driver
Our Fiat 126 with full cage and NA 2332cc and half a tank of fuel- 670kg- planning a diet to get her slimmer by 50kg. Needs to run low 11s to be competitive.
Bugeyed- about 600kg
Bugster 550kg
11.2@124mph
Pages: 1 [2] Print
