September 22, 2026, 08:29:27 am
| | |-+  48DRLA body bore internal diameter
Author Topic: 48DRLA body bore internal diameter  (Read 6420 times)
181
« on: February 29, 2012, 22:14:32 pm »
By chance, because my carbs are mounted in the car which is 100 miles from me in winter storage.
What is the exact internal diameter of the body bore? Is it consistent all the way down? I´m specifically interested in the area, where auxiliary venturi sits against the body. Can somebody measure for me? Thank you, Jan
« Last Edit: February 29, 2012, 22:18:21 pm by 181 » Logged
181
« Reply #1 on: March 01, 2012, 22:47:02 pm »
anybody? If somebody can measure for me an outside diameter of 48 DRLA venturi, that would be great!
ED2.4
« Reply #2 on: March 02, 2012, 17:06:23 pm »
45.7mm for vents ,46mm for the carb bore ,and 48 mm on the down side of butterflys
DeluxeRacingTeam >>>>  http://charlie48ida.skynetblogs.be/
« Reply #3 on: March 03, 2012, 07:08:32 am »
I believe the Aux-Vent for 48 DRLAs is the same one as for 45s.
ED2.4
« Reply #4 on: March 03, 2012, 10:25:47 am »
Hi,
not the same auxiliary vents between 48s and 45s , possible to made 45s aux-vents with 40s aux-vents  P/N 10078.1 (not the 12189) by removing a big part of the  ring
vents have the  same OD (42mm) on 45s and 40s
181
« Reply #5 on: March 04, 2012, 19:27:50 pm »
thanks a lot, valuable info!
