September 23, 2026, 13:37:43 pm
scat rocker studs
Topic: scat rocker studs (Read 3341 times)
henk
scat rocker studs
March 02, 2012, 12:46:26 pm »
i have a set of 1.4 scat rockers for my engine.
in the are the studs that hold the rockers to the cilinder heads.
these are a bit thicker then the ones that are in my heads now.
should i replace them or should i leave the ones that are in it now?
and what is the best way to get them out if i need to replace them?
henk!!!
fredy66
Re: scat rocker studs
March 02, 2012, 13:16:31 pm »
you need to swap them !
double nut them and remove
arabia slugs
henk
March 03, 2012, 11:27:38 am »
ok thanks.
gonna try it that way.
henk!!!
