September 22, 2026, 10:18:39 am
Questions on CB CNC Heads on street motors driven long range...
Topic: Questions on CB CNC Heads on street motors driven long range... (Read 34393 times)
rick m
March 07, 2012, 08:01:50 am »
How many of you are running any of the CB CNC heads on the street? What have you noticed in terms of the heads holding more heat than a VW factory head? Have you found that your motor is more difficult to cool due to the mass of material in the intake port area that has no means of air flowing through them like a stock VW factory head that has been ported? If you had a choice, would you run the CB CNC heads on a street engine or a set of TIMS State 1 or Stage 2 heads?
Would be interested in everyone's feedback. I figured there is a pretty good cross section of people on this forum that have run both. I have always run welded VW heads in the past an never experienced any difficulty in cooling a big motor due to the fact you can still flow air through the head. I see this as a challenge on the CNC heads that have the thick combustion chambers and solid intake port area. I an only interested in people who have actually put the CNC heads on a street motor 2110 or larger and driven them for distances (Road Trips, etc.). Not interested in speculative opinions from those who have never run them.
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
Re: Questions on CB CNC Heads on street motors driven long range...
March 07, 2012, 09:35:00 am »
Geez Rick -- What a list of requirements --- But I guess I qualify -- Ran the Ultra Wedge ports on the Fiat with a 2165 and Turbo'd -- great heads -- flowed real well -- Made over 325 HP at 20 lbs boost -- wouldn't hesitate to drive the Fiat anywhere and never seemed to have heat issues -- -- ran 100LL aviation fuel in it all the time -- so my trips were limited to how far I could go on a tank of gas (7 gallon stock size tank)
http://selvedgeyard.com/
Jason Foster
7.69 87mph 12.35 106 mph
March 07, 2012, 09:38:21 am »
I run slightly reworked wedgeports they work fine. I feel you are overthinking these issues build it drive it beat it up smile repeat.
rick m
March 07, 2012, 13:51:48 pm »
Jason,
I already built it and have 2500 miles on it. It is the first large VW motor in 42 years I have not run modified VW heads on and I am having issues with temp. I drive my car in all conditions and in temps most people do not ever see in So Cal during the summers. So, my reasons for being concerned are legit. My last large street engine had NO issues with heat and they were factory VW heads that were modified with all the correct cooling features still available. Yes, you can drive the wedgeports on the street. That is not the issue. The issue is the mass of aluminum that fills the intake area and the combustion chamber area and acts as a heat sink without the same air flow going through the head that a factory head is capable of allowing.
My motors with modified VW heads could be driven in any conditions and not overheat on me ever (with jetting and timing all being correct).
RM
Rick Mortensen
March 07, 2012, 14:24:52 pm »
hi Rick
are you seeing high head temps or high oil temps? I have not got much experience doing big milage in temps like you get there but havent seen any problems with the 044 casting creating excesive heat in So cal or europe,when you had welded heads in the past were they not filled in there as well?
Frenchy Dehoux
March 07, 2012, 16:27:53 pm »
LOL !!!!!!!!!!!!l LOL !!!!!!!!!!!!
Frenchy
Doctor Detail ( Retired )
rick m
March 07, 2012, 17:53:38 pm »
Richie,
I did not have the head welded all the way across. Usually just the top of the runners. I like the idea of having air flow over and around the port areas.
RM
Rick Mortensen
rick m
March 07, 2012, 17:55:39 pm »
Quote from: Frenchy Dehoux on March 07, 2012, 16:27:53 pm
Frenchy....whats up with this?
?? I don't remember you driving your cars in Phoenix for any distances like we have on road trips. RM
Frenchy
Rick Mortensen
Dominick Luppino
March 07, 2012, 18:11:38 pm »
I've had the same CB wedge port heads on my daily driver for 6 years now with zero problems, 2332 pump gas making 190hp and just built my sons 2332 with the Ultra Wedge ports making over 215hp on pump gas, they run cool on the street.
John Palmer
March 07, 2012, 18:13:17 pm »
Quote from: rick m on March 07, 2012, 17:55:39 pm
Frenchy
Frenchy, is probably trying to put some V-12 Flat Heads on a VW.
John Palmer
March 07, 2012, 18:15:39 pm »
Quote from: Dominick Luppino on March 07, 2012, 18:11:38 pm
Agree, we run CB CNC heads on both our race car and street cars. No problems with heating or durability.
March 07, 2012, 18:26:52 pm »
Rick -- using your reasoning on filling up the hole is causing it to get hot -- that means I'm really screwed with my next street engine by using these cylinders
or these heads
This engine does run hotter than a stocker -- but the temps have never gotten to a point where I'm worried
Last Edit: March 07, 2012, 18:31:45 pm by Fiatdude
March 07, 2012, 18:55:38 pm »
Quote from: rick m on March 07, 2012, 17:53:38 pm
Richie,
RM
That makes sense,so how high temps are you seeing?
March 07, 2012, 19:23:32 pm »
FiatDude,
Talk about apples vs. oranges! Besides, the
Angleflow
and 4" bore was proven street combo by someone else
And, aren't you running e85? Come on, give us a break ... not helping!
Rick,
There has to be another factor or overlooked adjustment, although hard to believe!
Those castings just aren't so terribly different from stock castings. BTW, my Fumios are welded between the ports as well with no problems, especially on highway cruises (rpm maintained 33-3500).
Perhaps timing adjustments can be tried first since it's the easiest adjustment to make (not including restting idle and synch). I know what you're up against without a dyno in my garage either
Hmmm ...
TxT
Last Edit: March 07, 2012, 19:27:52 pm by TexasTom
Frenchy Dehoux
March 07, 2012, 19:29:08 pm »
Sorry you are taking this the wrong way Rick. I was laughing at Fiatdude post.
Frenchy
Frenchy Dehoux
March 07, 2012, 19:30:57 pm »
Quote from: John Palmer on March 07, 2012, 18:13:17 pm
Frenchy
Hi John how is your Dad doing?
rick m
March 07, 2012, 19:33:13 pm »
Frenchy....Just yanking your chain too....all in fun! I am running a different ignition than in the past and could be having issues with that alone. Have never run into this and not been able to sort it out.
RM
Rick Mortensen
March 07, 2012, 23:20:36 pm »
Have given up trying to run E85 -- it was playing hell with my fuel system -- Still thinking about it but would have to redo my tank and get rid of all my rubber fuel lines -- But it does drop the head temps by over 100 degrees
Nope back to running my airplane gas 100LL
kingsburgphil
March 08, 2012, 04:10:31 am »
Quote from: Fiatdude on March 07, 2012, 23:20:36 pm
Sorry to hear you're soured on E85, but I can't say I blame you. I re-checked my oem stock tank today and the rust line appears to be more of a stain than crusty corrosion. I'm trying some fuel additives that claim to prevent corrosion, wish me luck. I hope your AP's run cooler than my CE's did on gasoline. And you're right about the 100 deg cooler head temp. But unless I reconfigure my engine and lower the trans, the E85 will stay. GM and Chrysler have flex-fuel cars using engine management components not unlike your's, save for the tank, lines and software. I think you're really close to having a killer combination, loads of power without melting pistons.
Isn't there an old adage about it being darkest just before the dawn.
March 08, 2012, 07:24:41 am »
Am I the only one who drives a VW big distances with a big motor?
Rick, my heads are the CB castings with the thick intake flanges.
I think the biggest reason they're reliable is all the extra mass everywhere, especially around the chambers. Sure they have slightly less cooling fin area, but I think the mass helps offset this.
You can improve them. Make sure you port the cooling fins. Use your cutoff wheel to clean up the casting flash between the fins, beside the exh ports. I also used lots of drills around the exh port. I don't specifically remember about the area between the intakes, but if there's room, I drilled holes.
Another improvement you can make is to make a plate to go on the underside of the fins between the two cylinders. Factory heads have a small steel piece there. The CB heads have nothing. This piece forces the cooling air that passes between the chambers to continue through the fins before dumping out.
On long trips in hot weather, I use a reinforced 36hp lower pulley to speed up the fan.
Although I don't have a head temp gauge, the highest I've seen the oil get is 260ºF, but that was a long time ago, and I don't go near that range anymore.
The worst I've subjected this engine was about 7-8 years ago, while in the Sonoran desert. I held it at around 115 mph for 15 min. I'm sure the heads got pretty hot then.....
Currently there's 70k miles on the engine.
Fasterbrit
March 08, 2012, 09:23:15 am »
Hi Rick. I regularly use 044s of all configurations right up to wedge. Never had a heat issue. One customer example is a 2276, 10.5:1 with fk87 and Ida's. No additional oil cooler and it runs perfectly normal temps with the oil rarely exceeding 100c and head temps in the safe zone. This car is driven street miles and on the strip where it runs mid twelves. I use all original tinware with the 'tents' lightly modded. I extend the Cyl head tins to compensate for the stroke. I also using the stock directional cooling vanes welded in the fully open position. I literally can't get this motor anyway near 'hot'.
Maybe there is another issue causing your excessive heat? From my observations even forgetting to fully push home the spark plug boots resulted in a 50f rise in head temps!
Possibly a lean condition?
Oh, and I always use race spec fully synth with zinc additive. Less friction = less heat to absorb... Cue dino versus synth debate...
Regards, Keeno
Last Edit: March 08, 2012, 09:27:07 am by All Torque
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
March 08, 2012, 10:03:47 am »
Chop top? I know this may sound daft,but were any of the other cars you drove big milage in chopped? the chop totally changes the way the air reaches the engine bay,I know someone who had the same problem in a chopped car with just a stock 1600,he was lucky enough to get it into a wind tunnel,and there he saw what was happening,the air travelling over the roof was now being forced away from the engine bay before it got there,it only got as far as the rear window,then turned upwards due to the shape there and the angle it hit the bottom of the window/rubber seal,it was causing the air to be sucked away from the engine and causing it to overheat
magic
March 08, 2012, 17:54:24 pm »
Hey Bruce,
No you're not!
I'm driving a 2,7l type 1. What is "big distance"? In the summer months I'm often on 100, 200, 300kms. trip and at least once a year it's a 1000kms. one.
I'm from northen Europa so we'er talking seasons here ( would NEVER expose my car to salt!!).
Of course we'er not packing the same heat as some of you guys,
maybe 15 - 30deg. C...
My machine is running a 11.1 to 1 comp. And running on shell V-power (99) And my patience is not for driving under 120kms/hr. on freeways of course
and the oil never reaches temp. Over 100deg. C
Ohh... nearly forgot, my 64 is a shop-top!!! Ok ok... Only 5.5cm.
Sorry....... Couldn't resist!!!
cheers magic
Last Edit: March 08, 2012, 17:56:08 pm by magic
March 08, 2012, 19:02:01 pm »
Quote from: Bruce on March 08, 2012, 07:24:41 am
044 on my car driven over 1500 miles a month every month no matter the weather, same heads since 2008, no heating issues I run Santana power pulley BTW
Jeff68
March 08, 2012, 19:09:19 pm »
This is a great question / post! I don't know if my engine qualifies. I drive my car on occasion on 130 mile trips on the freeway with the engine turning around 4000 rpm. I live in Florida and humidity and ambient temperature can be high for both. The terrain here is very flat, with no major grade to speak of. The engine is a 2110 82 X 90.5 - 8 to 1 compression, K10 cam, 48 IDA's, CB044 (42 x 37.5 valves) castings that were CNC ported to 870 type heads by the Bergs (I bought these heads from you RIck). I pushed the engine pretty hard once on the freeway going around 100 mph for 10 minutes if I remember. The oil light did flicker after about 8 minutes or so and when I slowed down to 65 mph (around 4000 rpm) it eventually went out. I don't have gauges so I don't know what the oil or head temps were. In regular around town traffic the engine never runs hot with short high rpm bursts. Hope this helps.
magic
March 08, 2012, 21:46:32 pm »
wow.. Totaly forgot the main question on the thread! ( and a interesting one!)
Abaut the heads, mine's JPM 230 4" ( more precise, machined for 102mm. JE pistons)
Who I think are superior in cooling, compared to some aftermarket raceheads,
say sf, ce, angle flo, or 910, and so on.
But not as cool running as a pair of 044!! (And that was the hole point)
magic
kingsburgphil
March 09, 2012, 01:34:53 am »
Quote from: Jim Ratto on March 08, 2012, 19:02:01 pm
Jim, I'm curious how your car behaves on the "grapevine" (I-5) or do you take Rt.101 when you go to LA/OC? If you take the I-5, do you pull the hills in 4th.?
Or spin it up in 3rd. at a lower mph.
Jason Foster
March 09, 2012, 04:23:27 am »
Aluminum case? or Mag? I'm seeing higher temps (oil) with my aluminum case added cooler and all is good now though. Hope I didn't piss ya of BTW.
March 09, 2012, 06:40:13 am »
Quote from: magic on March 08, 2012, 17:54:24 pm
Hey Bruce,
No you're not!
While that is a pretty big engine, those are all short trips.
Get your map out and locate Vancouver Canada. Then locate Cancun Mexico. Round trip is about 14,000km. I think that trip was either 6 or 8 weeks. On my last trip, I drove the Pacific coast highway to Acapulco, then back through Mexico City. Elevations top 3500m, and temps approach 40ºC.
I usually watch the oil gauge and slow down when it gets to 230ºF (110ºC)
Oh ya, I forgot about Jim. I bet he drives his car more than anyone else in the club.
Last Edit: March 09, 2012, 07:03:50 am by Bruce
rick m
March 09, 2012, 08:23:12 am »
This has been a fun post indeed. I do long trips too Bruce. That last one and longest one for me was to Detroit, Michigan, and back to Phoenix. I thought I could get quite a rise out of everyone on this one. There is a big difference between driving 1500 miles a month...and driving 700-100 miles one direction.
My motor is a 2275, K8 Cam, 8.7 compression, with IDAs. I have it running at 180 degrees. It will bounce up to 200-2010 if I beat it hard but it will come back down to 180 while cruising. It has a BERG wide 3.5 qt sump, type 4 cooler, custom made tin that fits tight with little air gap under the motor...so everthing exits to the rear. I run a BERG stock size crank pulley and a 912 alternator pulley. Gives the motor a little more air speed at a lower RPM. I run a 3.88 ring and pinion and I am doing about 69mph at 3400 rpms. At 3000 rpms I am around 63mph. The smaller alternator pulley helps keep the fan speed up at the lower rpm.
I am preparing the chop for a road trip to visit an old friend, Ray Vallero, and then on to Kelly Park in April. I had a few challenges dialing in the COMPUFIRE DIS ignition set up where I wanted it but it runs fine now.
The chop top has not affected the cooling whatsoever. The air stream still hugs the roofline and goes directly into the vents below the rear window. We taped some pieces of nylon string to my roofline above the chopped rear window with duct tape and drove the car at 65 mph up grand avenue near where I live. A friend followed on his motor cycle and said the nylon string literally was sucked into the vents below the rear window when we were at speed. So, the theory about the air not following the roofline (as designed by the original VW engineers) does not apply to my chop. It still gets the air that flows over the roof into the engine compartment.
I did prop the bottom of my decklid out about 2" which helped the engine compartment with a little more air volume. Keep in mind that a 1300-1600 cc motor, with a 30 or a 34 pict carb does not suck as much air out of the engine compartment (through the vents above the decklid) as a 2276 air pump being fed by 48IDAs. So, with all the air the motor is requiring, some of that air calculated for cooling is somewhat diminished. The engine compartments need more air for the motor and for cooling.
Fun to hear everyone's perspectives. Try driving one of those motors you've all talked about in Arizona when the ambient air is 110 and the pavement is 145 to 150 degrees. It takes a lot to drive a Hot VW in Arizona. My issues were simple tuning issues but I sure got the conversation going with what I threw out! I am finishing up the final touches on my car...including HAL Meter to keep an eye on the A/F ratio on my trip. I carry a couple extra sets of jet stacks with different mains and air correction jets already set up for quick changes. It will be interesting to see how my tune works from Arizona to Nor Cal and back with the IDAs.
Rick M
Last Edit: March 14, 2012, 15:18:19 pm by rick m
Rick Mortensen
