September 22, 2026, 03:39:29 am
| | |-+  2" narrowed link pin beam
Author Topic: 2" narrowed link pin beam  (Read 21414 times)
Wired1
« on: March 07, 2012, 08:32:51 am »
I am narrowing a link pin beam for my '63 beetle. It is currently running dropped spindles and Empi-5 GTs with 185/65 tyres up front and they hit the guards under braking - fender braking we call it down here.
I have pinched the beam out of my '67 beetle which is getting ready for IRS conversion and the Baja treatment so I can still drive the Red bug while I build the beam. There isn't a lot of information about how to do this so I will make a video of it when I'm done.
So far I have measured up the original beam, removed it from the car and taken it home from my workshop in town to start chopping it up.
I am taking 1" out of each side as this will give me 1/2" clearance off the fender and that is all I need. I'm not a fan of the narrowed look. I'm also not fitting adjusters as the ride height is exactly right. I found some exhaust tubing that is exactly 44mm OD which is the same ID as the beam and I will use this to sleeve the joins.
We have one of the strictest vehicle inspection systems in the world in enzed with compulsory inspections every six months so I want it to look as stock as possible.
For the same reason I'm also going to slim and plate the towers so that it still looks stock.
« Last Edit: March 07, 2012, 08:34:48 am by Wired1 » Logged
1967 baja project - 1963 beetle driver - http://www.youtube.com/user/wiredkiwi
Fasterbrit
« Reply #1 on: March 07, 2012, 10:37:34 am »
Good work! Nice to see a post from Downunder  Cool
www.air-kraft.com
www.marcomansiperformance.com
Richyrich
« Reply #2 on: March 07, 2012, 23:30:18 pm »
Nice, love this home build stuff, and from NZ as well, cool. keep up the work Bud..
Wired1
« Reply #3 on: March 09, 2012, 07:44:58 am »
Thanks guys, got a bit of welding done this evening after work - my ideal Friday night Smiley
Wünderwolff
aka Dr. Jeckill
« Reply #4 on: March 09, 2012, 08:22:25 am »
I know it's a bit late for that now  Grin But maybe the next beam?
But in order for the narrowing beind less conspicious, I cut the two tubes behind the two shell that are used to tighten the axle to the chassis. I grinded them of first and welded them back on after the operation. This way I could really weld hard without the welds showing at the tech control.
Wünderwaffe are Go!
Wired1
« Reply #5 on: March 09, 2012, 09:13:52 am »
Yes someone else said that locally too - you do have to take the clamps off and move the steering box locaters but neither of them are hard to do.
Wired1
« Reply #6 on: March 09, 2012, 23:06:14 pm »
Welded up and smoothed back. Then a nice thick coat of primer...
« Reply #7 on: March 10, 2012, 12:32:30 pm »
Nice work Grin
Wired1
« Reply #8 on: March 11, 2012, 05:36:47 am »
Thanks, I'm picking the best photos of course  Wink
Shortened the torsion bars and re-countersunk the grub screw holes. Looks like stock again...
Wired1
« Reply #9 on: March 11, 2012, 09:03:29 am »
<a href="http://www.youtube.com/v/X5k6w65hS70" target="_blank">http://www.youtube.com/v/X5k6w65hS70</a>
« Last Edit: March 11, 2012, 09:08:59 am by Wired1 » Logged
IP359
« Reply #10 on: March 11, 2012, 09:19:11 am »
Very interesting video Wired1 !
Don't hesitate to share next ones
« Last Edit: March 11, 2012, 19:46:17 pm by IP359 » Logged
Wired1
« Reply #11 on: March 13, 2012, 05:59:29 am »
Will do thanks, I've got a few on Youtube (http://www.youtube.com/user/wiredkiwi) showing ball joint and link pin beam mods plus a motor rebuild and a few motorcycles I've restored. All good fun.
Wired1
« Reply #12 on: March 14, 2012, 07:53:12 am »
These arrived today from the laser cutter, I drew them up using a pencil and paper and they translated it to a dxf without a comment on my archaic drawing. These are for the beam I take out of Red Bug when I put the narrowed one in and will also have adjusters in the middle of each pipe. I measured the above beam today and it has ended up 60mm narrower than stock (about 2 3/8"). The next one will be 100mm (4") easy and still fit like stock.
« Last Edit: March 14, 2012, 07:57:33 am by Wired1 » Logged
Wired1
« Reply #13 on: March 24, 2012, 05:01:20 am »
Swapped over the beams today and it took most of the day. The narrowed beam was a snug fit but clears the inner guards by about 5mm and there is no squeaking when you are driving so I guess it's clear. It would be very difficult to go any narrower than this (60mm) with stock towers.
Amazingly the wheel alignement was exactly right just by sheer good luck. I shortened the track rods by 25mm each and assumed I would have to adjust them, better buy a lotto ticket I guess.
It drove really well on the test run and no fender braking now - hate that noise.
Seeing how this fits I will rebuild the beam that came out with the custom towers I had made and will make it about 3" total narrowing which will end up with a good 10mm clear of the inner fenders but still fill the fenders nicely. I will also fit adjusters to the next one as it would be nice to be able to fine-tune the height.
Movie to follow of course Smiley
Wired1
« Reply #14 on: March 24, 2012, 11:59:46 am »
<a href="http://www.youtube.com/v/1EGeTgqHlkc" target="_blank">http://www.youtube.com/v/1EGeTgqHlkc</a>
