September 22, 2026, 23:56:45 pm
| | |-+  Titanium Valve - roller tip rocker - Manton HD thick wall cro-moly..........
Author Topic: Titanium Valve - roller tip rocker - Manton HD thick wall cro-moly..........  (Read 4326 times)
Shane Noone
« on: March 10, 2012, 20:45:34 pm »
Hey Guys,
After your thoughts and advice please. Today took a look at my valve lash clearances ( checked stone cold ) and found that all my Titanium inlet valve clearances were tight enough so that I could not either turn the pushrod with my fingers or roll the roller tip !!  Is this too tight with the combo of Ti valve / Pauter roller tips / Manton HD cro-mo pushrods Huh?  ( I don't have feeler gauges that go down past 4/ 6 thou but will try and get some below 4 if needed ? )
I backed all the inlets off so that I could rotate the pushrods albeit tightly just as a pre-caution as the car does get street driven so varying heat ranges / engine speeds on the motor. But is this a good idea Huh
Cheers, Shane.
« Reply #1 on: March 10, 2012, 20:59:15 pm »
Shane,
you are only losing lift,its worse if they are to tight,its possible to burn a valve if its held open,on the street a little extra lash wont hurt,you can always check them at the track,and tighten them up a little if needed,you proberly have about 0.025 - 0.030 thou lash when it is really warmed up,i prefer to set them by feel,you wont get it right with feeler guages when you are looking for only 1-2 thou
cheers richie
Shane Noone
« Reply #2 on: March 10, 2012, 21:07:58 pm »
Richie, yeah that's what I figured and I realise trying to use feelers at such small clearance will be a nightmare anyway.
When you say by feel, that is what I meant by setting the lash almost to zero cold but I figured you should still be able to rotate the pushrod with your fingers. Before I backed them off, I couldn't do this or roll the tip, so figured the valves could be held open slightly all the time and I wouldn't really know ?
What do you think ?
Cheers,
Shane.
« Reply #3 on: March 10, 2012, 21:22:14 pm »
the valves have proberly settled into the seats a little tightening them up,it really is a knack getting them tight,but still being able to spin the pushrod,better loose though,practice will help Cheesy
cheers richie
