November 02, 2026, 16:26:39 pm
What head studs??
Topic: What head studs?? (Read 7527 times)
What head studs??
March 20, 2012, 21:01:40 pm »
Hi Guys,
Almost got all the bits to have my new race motor built. One thing I do need are head studs in 10mm size.
Brief engine spec is 2276cc, fk89, wisecos, comp eliminators 48x38, IDA's and 12:1 cr
What do you recommend?
Links to suggestions would be ace
Leif Nyström
Re: What head studs??
March 21, 2012, 17:57:44 pm »
http://www.vwparts.net/RWE-1004.html
Hotrodvw
March 22, 2012, 06:24:44 am »
I'm using the Scat 8mm studs for my 94mm barrels. I think they're easier to fit than the 10mm. I'm going 10.5:1 c/r, and will hold just fine.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
March 22, 2012, 20:31:17 pm »
CSP only , they are good german 10.9 quality
www.Udobeckertuning.de
Bernard Newbury
9.50 @ 141 MPH
March 22, 2012, 21:29:19 pm »
Quote from: Leif Nyström on March 21, 2012, 17:57:44 pm
Raceware
http://www.raceware-fasteners.com/photo.htm
Bernie
james wotton
March 22, 2012, 22:17:06 pm »
racewear for me
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
March 23, 2012, 04:07:02 am »
While Raceware is a very nice and stout product, there is no need for them in such "mild" engines. Std CB/Scat 8 or 10 mm studs holds up fine up to about 12,5/1 CR with an FK89 and similar in the 230-240ish range. With turbo or nitrous of the serius kind Raceware is the ticket.
The CSP stud kit is ok. I dont like the nuts, and always replace them, and use the CSP nuts for rocker arms etc.
March 23, 2012, 07:12:10 am »
Are the 10mm original studs good enough the Red Baron I guess they should be good enough for most of us?
Ragtop
8.93 at SCC 2012
March 23, 2012, 08:57:16 am »
I am not in the same league as the Baron but I also use VW original 10 mm.
Shag55
Shag Leone, SL-1racing
March 24, 2012, 01:02:08 am »
OG studs are fine. I use the Raceware's on mine but they are turbo motors. I'd go with ARP nuts with the OGs.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
March 25, 2012, 01:55:02 am »
OEM stock 8 mm until which are pretty good if new and not corroded plus not tightened mor ethan stock.
Then I started buying at Raceware from Randy Hubbard in 1994. Quality and excellent service in combination.
Never looked back.
Both headstuds and through the block bolts.
Some of my cars:
neil68
March 25, 2012, 03:43:35 am »
Quote from: Hotrodvw on March 22, 2012, 06:24:44 am
Same here, Scat 8 mm studs and nuts, with JPM 48 x 37 heads, 10.6:1 CR, 94 mm Mahle cylinders (slight trimming of the grooves required to clear the studs).
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
