October 13, 2026, 08:14:39 am
| | |-+  coil bind
Author Topic: coil bind  (Read 17010 times)
henk
« on: March 25, 2012, 19:38:05 pm »
hallo,
the heads and rockers went on my engine today,but it seems like it has coil bind.
what is the best way to solve this probleme from coil bind?
whitout changing the cam off course.
the cam is an FK-10 and the rockers are 1.4 scats
can i do some modification on the heads or so to solve this?
henk!!!
« Reply #1 on: March 25, 2012, 19:45:18 pm »
Longer valves.
Bore the pockets for the springs deeper.
Shorten the springs.
Taller retainers.
tezer
« Reply #2 on: March 25, 2012, 19:52:21 pm »
what brand springs you have?
i had to get cb vw650 to fix my coil bind problem!
Chris bugster
« Reply #3 on: March 26, 2012, 13:23:59 pm »
Yes indeed, Mr Tezer is correct. A set of Scat 1.4s I have lifts close to 1.5 and with an FK10 I had I ended up with almost .600 lift, which is far too much for the dual spring setup found on most performance heads and so one option is to use the CB 650 springs or those from JPM.
11.2@124mph
henk
« Reply #4 on: March 28, 2012, 09:46:47 am »
ok thanks guys,
it seems indeed that it would work with the CB 650 springs.
i'm also gonna have to machine the titanium retainers a bit down as these are touching the valve guides.
don't think this wil be a probleme,only have to shave of 3mm?
henk!!!
ibg
« Reply #5 on: March 28, 2012, 13:38:30 pm »
Machine the valve guides not the retainers. A couple of mm off a guide is nothing, 2 mm off a retainer is lots. you run the risk of the retainer pulling through. Shocked
Big Power
« Reply #6 on: March 29, 2012, 16:05:07 pm »
You really need to install some "checking" springs and find out what your total lift is. You then need to check your installed height. The vw 650 spring with a retainer that has a .100 outer spring step will coil bind at .850. You need at least .050 before coil bind.
« Reply #7 on: March 29, 2012, 17:36:14 pm »
I would also change to the CB springs and different rockers. Scats have different ratio in one set. From 1,3-1,5 . But it sounds like you have to grind the spring seat too. Watch for breaking through in the intake port
henk
« Reply #8 on: March 30, 2012, 09:58:40 am »
ok guys,
thanks for all the info.
i orderd the CB650 springs and see if this will solve the probleme.
also gonna machine down the valve guides instead of machining the retainers.
let you know how it goes.
henk!!!
« Reply #9 on: March 30, 2012, 17:45:56 pm »
order the retainer with the springs ... That should give you more room
henk
« Reply #10 on: April 06, 2012, 21:00:19 pm »
ok,springs are in and the valve guides are trimmed down 2mm.
everything clears now and i have no coil bind anymore.
it really starts to look like an engine now. Smiley
henk!!!
« Reply #11 on: April 07, 2012, 00:05:23 am »
No it doesn't -- at least until a turbo is installed   Grin Grin Grin
« Reply #12 on: April 07, 2012, 00:35:09 am »
When you put those on all you can see is the hairdrier or tubing ... blocks the view of simplistic beauty.
Looks Great, Henk!
TxT
« Last Edit: April 07, 2012, 00:36:44 am by TexasTom » Logged
henk
« Reply #13 on: April 08, 2012, 11:45:40 am »
thanks,
had a LOT of help ont it from a friend(Steve) with that engine.
henk!!!
« Reply #14 on: April 09, 2012, 02:17:45 am »
Looks Great, Henk!
TxT
Com'on how does all this block the beauty    Roll Eyes Roll Eyes Grin Grin
But it does look great Henk
« Last Edit: April 09, 2012, 02:19:45 am by Fiatdude » Logged
« Reply #15 on: April 09, 2012, 05:04:43 am »
henk!!!
Nice looking
what travel do you have between full lift and coil bind now?
Fasterbrit
« Reply #16 on: April 09, 2012, 10:12:29 am »
Great turbo install  Cool
Your air filter will be picking up a lot of heat though; reducing your intercooler's efficiency somewhat. Some extra hp to be had by a simple relocation  Wink
www.air-kraft.com
www.marcomansiperformance.com
m.o.t
« Reply #17 on: April 09, 2012, 12:50:11 pm »
Quote
aprox. 1,8mm...
steve
