September 22, 2026, 23:16:54 pm
| | |-+  Bleeding brakes with hydraulic hand brake??
Author Topic: Bleeding brakes with hydraulic hand brake??  (Read 4823 times)
Mkracing
« on: March 26, 2012, 22:06:15 pm »
Hi guys, is there any speciel way to bleed the brakes with a hydraulic hand brake??
I have CB wide 5 brakes in the front, and csp 205 mm race brakes in the rear. But I think the hydraulic hand brake causes some problems. I Also have line lock installt.
The pedal goes way down to the floor...!!
And there is no leake anywere!!
Morten
Basti
« Reply #1 on: March 27, 2012, 07:39:13 am »
Hi Morten!
I had the same problem!
Pump 3 times with the pedal, open the valve at the calliper, and pump one time with the handbrake,
hold the handbrake and close the valve.
Do this 2 or 3 times round the car and you have preassure on the pedal...
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Mkracing
« Reply #2 on: March 27, 2012, 14:29:52 pm »
Okay, thanks Basti, I will try that;-)
Mkracing
« Reply #3 on: April 25, 2012, 19:41:19 pm »
Still can get the brakes to work as I will. Can it be the master cylinder?? Its the one with (20.64 mm) Is it to big, for the small kalibers from strange enginering??
